HP LaserJet Pro M1536dnf, M1537dnf, M1538dnf, and M1539dnf Multi-Function Printers - Setting Up the LaserJet (Hardware)
  • Unpack the product
  • Remove packing tape and attach trays
  • Insert the cartridge
  • Connect the power cord
  • Turn on the power
  • Select the language
  • Load plain paper
Setting up the product
Do not connect a USB cable now. If you plan to use a USB cable to connect the printer to the computer, you will be prompted to connect it at the correct time during the software installation.
Step one: Unpack the product
Remove the product and other items from the box.
Figure : Unpack the product
Image:  Unpack the product
Step three: Remove the tape and packing material from the product
  1. Position the product on a sturdy surface in a well-ventilated, dust-free area that is away from direct sunlight.
  2. Remove all pieces of blue tape from the product.
    Figure : Remove tape from the product
    Image: Remove tape from the product
  3. Open the cartridge door.
  4. Lift up the paper packing material, but do not remove it.
    Figure : Lift up the paper packing material
    Image: Lift up the paper packing material
  5. Remove the cartridge packing material.
    Figure : Remove the cartridge packing material
    Image: Remove the cartridge packing material
  6. Remove the cartridge from the product.
    Image: Remove the cartridge from the product
    Hold the cartridge at each end to prevent damage to the cartridge.
  7. Remove the paper packing material from inside the product.
    Figure : Remove the paper packing material
    Image: Remove the packing material from inside the product
Step four: Attach the trays
  1. Attach the output tray by snapping it into place.
    Figure : Attach the output tray
    Image: Attach the output tray
  2. Attach the priority input tray.
    Figure : Attach the priority input tray
    Image: Attach the priority input  tray
Step five: Prepare and insert the cartridge
  1. Open the print cartridge door.
    Figure : Open the print cartridge door
    Image: Open the print cartridge door
  2. Remove the orange clip from the end of the cartridge.
    Figure : Remove the orange clip
    Image: Remove the orange clip from the end of the cartridge
  3. Gently rock the cartridge from front to back to distribute the toner.
    Figure : Rock the cartridge
    Image: Rock the cartridge
  4. Remove the sealing tape from the cartridge.
    1. Bend the tab on the left side of the cartridge until the tab breaks loose.
    2. Pull the tab to remove the sealing tape from the cartridge.
    3. Put the tab in the cartridge box to return for recycling.
    Figure : Remove the sealing tape
    Image: Remove the sealing tape
    If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric.
  5. Insert the cartridge into the product, and then close the cartridge door.
    Figure : Insert the cartridge and then close the door
    Image: insert the cartridge and close the door
Step six: Connect the power cord
Connect the power cord to the rear of the product, and then plug it into a wall outlet.
Figure : Connect the power cord
Image:  Connect the power cord
Step seven: Turn on the power
Press the Power button () to turn on the product.
Figure : Turn on the product
Image: Turn on the product
After you turn on the product, an 'Install black cartridge' message might display on the product control panel. If you receive this message, follow these steps to resolve the issue.
Step eight: Select the language
  1. On the control panel, press the Setup button ().
  2. Press the Right Arrow () to select System Setup, and the press OK.
  3. Press OK to select Language.
  4. Press the Right Arrow () to select your language, and then press OK.
  5. Press OK to confirm the selection.
Step nine: Load plain paper
  1. Slide the paper width and length guides to their outermost positions.
  2. Place a stack of paper in the tray, and then make sure that it is flat at all four corners.
    Figure : Load plain paper into Tray 1
    Image: Load plain paper into Tray 1
  3. Slide the paper guides in so that they rest against the stack of paper.
    Figure : Slide the paper guides in
    Image: Slide the paper guides in
