    Fix Windows 10 Update Issues
HP Designjet T770 and T1200 Printer Series - Practical printing examples
Print a draft for revision with the correct scale
This section demonstrates how to print a draft for revision with the correct scale from Adobe Acrobat.
Using Adobe Acrobat
  1. In the Acrobat window, bring the mouse cursor to the bottom left corner of the document pane to check the plot size.
    Figure : Acrobat main window
  2. Select File > Print and ensure that Page Scaling is set to None.
    Figure : Print dialog box
    The page size will not be automatically selected according to the drawing size.
  3. Press the Properties button and then select the Paper/Quality tab.
    Figure : Paper/Quality tab
  4. Choose whatever Document Size and Print Quality you want to use. If you want to define a new custom paper size, press the Custom button.
    Figure : Custom Paper Size dialog box
  5. Select the Features tab, and then Autorotate.
    Figure : Features tab
  6. Click OK, and check that the print preview in the Print dialog box seems correct.
Print a project
This section demonstrates how to print a project from Autodesk Design Review, AutoCAD and the printer's Embedded Web Server.
Using Autodesk Design Review
Autodesk Design Review offers the Use HP Instant Printing option. This needs to be enabled once, after which it is taken as the default printing option until it is disabled.
Enabling HP Instant Printing from Autodesk Design Review
  1. Start Autodesk Design Review and select File > Print.
    Figure : Autodesk Design Review, File menu
    Alternatively, click the Print icon on the toolbar.
    Figure : Autodesk Design Review, Print icon
  2. In the Print dialog box, check the Use HP Instant Printing box. You can select your printer and paper size here, or in the next window.
    Figure : Autodesk Design Review, Print dialog box
  3. Ensure that the printer and paper size are correct, then click OK to start printing.
    Figure : Autodesk Design Review, HP Instant Printing dialog box
Enabling HP Instant Printing from the Batch Print Wizard
  1. Make sure you have installed the Batch Print Wizard. Start Autodesk Design Review and select File > Batch Print Wizard.
  2. In the Welcome box, click Next.
    Figure : Batch Print Wizard, Welcome box
  3. Select the DWF files to print, then click Next.
    Figure : Batch Print Wizard, select DWF files
  4. Use the Shift key if you want to select multiple files to configure. Then click Print Setup, and the printing configuration will be applied to all the files you have selected..
    Figure : Batch Print Wizard, choose print settings
  5. In the Print dialog box, check the Use HP Instant Printing box. You can select your printer and paper size here, or in the next window.
    Figure : Batch Print Wizard, Print dialog box
  6. Ensure that the printer and paper size are correct, then click OK. The paper size is automatically preselected.
    Figure : Batch Print Wizard, HP Instant Printing dialog box
  7. Back in the Choose print settings box, click Next.
  8. Save or start the batch print job.
    Figure : Batch Print Wizard, save or start batch print job
Using HP Instant Printing
  • Make sure Use HP Instant Printing has been selected. To print, click the Print icon in the toolbar or select File > Print. Choose your preferred printing settings and click OK.
    Figure : HP Instant Printing dialog box
  • Alternatively, Use HP Instant Printing can be launched directly from its own toolbar icon. In this case, it starts immediately, using the settings you defined previously.
Using AutoCAD
  1. The AutoCAD window can show a model or layout. Normally a layout is printed rather than the model.
    Figure : AutoCAD window
  2. Click the Plot icon at the top of the window.
    Figure : Plot icon
  3. The Plot window opens.
    Figure : Plot window
  4. You can see further options by pressing the circular button in the lower right corner of the window.
    Figure : Advanced Plot options
    The Quality option here does not refer to the final print quality but to the quality of AutoCAD viewport objects that are sent for printing.
  5. Press the Properties button.
    Figure : Plotter Configuration Editor
  6. Select the Device and Document Settings tab, and press the Custom Properties button.
  7. In the Paper/Quality tab, check the Show preview before printing box, and select the paper type that you intend to use.
    Figure : Paper type selection
    If you select neither the paper source nor the paper type, the printer will not print on any protected roll (see Roll protection (T1200 series only)).
  8. Select the print quality (your own choice between speed and quality of printing).
  9. If you intend to print on roll paper, you must decide where the printer should cut the paper. Press the Margins/Layout button and select Clip contents by margins.
    Figure : Layout and Margins window
  10. Select the Features tab, then select the Autorotate option. If you have a T1200 series printer, select the Crop lines option also. Autorotation can help to avoid wasting paper, and the crop lines will show you where to cut the paper after printing.
  11. Press the OK button and save your configuration changes to a PC3 file.
    Figure : Saving a printer configuration file
  12. When you have pressed the OK button in the Plot window, the printer will construct a print preview (T1200 series only).
    Figure : Plot Job Progress window
    Figure : Waiting for print preview
    Figure : Print preview
Using the Embedded Web Server to submit files (T1200 series only)
From the HP Utility or the Embedded Web Server, select Job Center > Submit Job. With some Web browsers, you will see the window below; with other Web browsers, the mechanism for adding files is slightly different.
Figure : Submit Job page
Press the Add files button (or Choose File, Add another file) to choose the files from your computer that you want to print. The files must be in one of the following formats:
  • PDF (T1200 PS only)
  • PostScript (T1200 PS only)
  • TIFF (T1200 PS only)
  • JPEG (T1200 PS only)
  • HP-GL/2
  • RTL
When you print to a file, the file should be in one of the above formats, but its name may have an extension such as .plt or .prn.
If the files are not in one of these formats, they will not be printed successfully.
If the jobs have been generated with the appropriate settings (such as page size, rotation, resizing and number of copies), you can just press the Print button and the project will be sent to the printer.
If you need to specify printing settings, go to the Job settings section and select the options you need. Each option has explanatory text on the right, so that you can understand the behavior of each setting. Remember that, if you leave the setting as Default, the setting saved in the job will be used. If the job contains no setting, the setting in the printer will be used.
Using printer emulation
Printer emulation can be requested by selecting Advanced settings > Color > Color management > Printer emulation.
You can select Off (no printer emulation) or the name of the printer model that you want to emulate.
This setting will apply to jobs that do not contain any printer emulation setting saved in the job.
Using clip contents by margins
You can select this margins option from Advanced settings > Paper > Layout/Margins > Print with margins > Layout > Clip contents by margins.
Use this option when the contents to be printed have white borders and a size equal to that of the paper you have selected. The printer will use the white border for its margins and you will get a page of size equal to that which is selected in the driver.
Print a presentation
This section demonstrates how to print a presentation from AutoCAD and from Photoshop.
Using AutoCAD
  1. Open the AutoCAD file and select a layout.
    Figure : Plot icon
  3. Ensure that the correct printer is selected, then press the Properties button.
  4. Select the Device and Document Settings tab, and press the Custom Properties button.
  5. In the Paper/Quality tab, check the Show preview before printing box, and select the paper type that you intend to use.
  6. Select the print quality (your own choice between speed and quality of printing).
  7. If you intend to print on roll paper, you must decide where the printer should cut the paper. Press the Margins/Layout button and select Clip contents by margins.
  8. If you are using photo or glossy paper, you can select Borderless printing (T1200 series only).
    Figure : Layout and Margins window again
  9. Select the Features tab, then select the Autorotate option. If you have a T1200 series printer, select the Crop lines option also. Autorotation can help to avoid wasting paper, and the crop lines will show you where to cut the paper after printing.
  10. Press the OK button and save your configuration changes to a PC3 file.
  11. When you have pressed the OK button in the Plot window, the printer will construct a print preview (T1200 series only).
Using Adobe Photoshop
  1. Select File > Page Setup > Printer, select your printer and click OK.
    Figure : Page Setup window
  2. Choose from the available paper sizes.
    If you do not find the paper size that you intend to use, select Printer > Properties > Paper/Quality > Custom > Paper Size. Enter the width, the length and the name of your custom paper size. Press the Save and OK buttons.
  3. Select File > Print with Preview.
    Figure : The Photoshop Print dialog box
  4. Select Print > Properties. In the Document Properties window, select Paper Source, Paper Type and Print Quality.
  5. Press the Margins/Layout button. In this example you can select Borderless because you have already selected a photo paper (this option is only enabled with photo and glossy papers). The default image enlargement method is Automatically by printer. The option Manually in application can be used when you want to control the amount of enlargement precisely.
    Figure : Layout and Margins dialog box
  6. In the Color tab, the default color management option is Printer Managed Colors, and this is the correct option because you have already selected Let Printer Determine Colors in Photoshop.
    Figure : Color tab
Print and scale from Microsoft Office
This section demonstrates how to print and scale from Microsoft Office.
Using PowerPoint
  1. Select the Office Button, then Print, and select the name of your printer.
  2. Select Properties > Features > Print document on to scale the document to a particular size.
  3. Select the Paper/Quality tab, then select Paper Source and Paper Type.
    Figure : Paper Quality tab
  4. Select Margins/Layout, then select Clip contents by margins to keep the size.
Using Project
  1. Select File > Page Setup > Print.
    Figure : Page Setup dialog box
  2. Select your printer's name, then Close.
  3. Select Page Setup, and choose the Paper Size you want.
  4. Select Options to go to the printer driver. The default options in the Paper/Quality tab are probably suitable: Paper source: Printer auto select and Paper Type: Any.
  5. Select Features > Print document on to scale the document to a particular size. Alternatively, you can scale the document in Project.
Using Excel
  1. Select the Office Button, then Print. Select your printer's name, then click Close.
  2. Select the Page Layout tab, then Size, and choose the paper size you want.
    Figure : Paper size selection
  3. Select the Office Button, then Print > Properties to go to the printer driver. In the Paper/Quality tab, select Paper source, Paper Type and Print Quality.
  4. Select Features > Print document on to scale the document to a particular size. Alternatively, you can scale the document in Excel.
