HP Scanjet N6350 Networked Document Flatbed Scanner - Unable to Connect to a Network
Issue
Scanner is not getting detected in the network or shows error can not find the scanner.
Solution
This issue can be due to either scanner hardware or network setup where scanner is connected. This document explains some simple steps to test and isolate the issue.
Install scanning software into an independent PC or laptop. This will install both scanning software and scanner tools utility. Connect scanner directly to PC with a crossover cable and power On.
Now assign IP manually to scanner.
Click on setup button, Network, Network setup (select automatic to Off), IP Address, manual and type IP and subnet. Assign IP in the same range that PC has.
Example: PC IP - 169.254.213.25, Subnet - 255.255.0.0.
Scanner IP - 169.254.213.26, Subnet - 255.255.0.0.
This scanner is designed to work in the same subnet.
Once IP is assigned, open scanner tools utility and click connect scanner. It will run network setup and search for hp scanjet N6350 scanners as shown below.
Network setup can not detect scanner if network card is faulty or no connectivity. It will show message as shown and prompt to search again. Try Advance search option.
If network card is functional, it will get detected by IP address as shown.
Once device is detected, select from the list and click next.
Now try some test scans to verify the functionality.
This way one can test and isolate the issue.
