HP Designjet T770 and T1200 Printer Series - Connect to a network (Windows)
Before you begin, check your equipment:
  • The printer should be set up and on.
  • The Ethernet hub or router should be on and functioning correctly.
  • All computers on the network should be on and connected to the network.
  • The printer should be connected to the network.
Now you can proceed to install the printer software and connect your printer:
  1. Make a note of the printer's IP address from the front panel (see Access the Embedded Web Server).
  2. Insert the HP Start-Up Kit CD into your computer. If the CD does not start automatically, run the autorun.exe program in the root folder of the CD.
  3. Press the Express Network Install button, and choose your printer from the list of networked printers that appears, identifying it by its IP address if necessary. The printer drivers and the HP Utility are installed.
If your computer fails to find any printers on the network, the Printer Not Found window is displayed, which helps you to try to find your printer. If you have a firewall in operation; you may have to disable it temporarily in order to find the printer. You also have the options of searching for the printer by its URL, IP address or MAC address.
For additional network settings information, go to Configure Network Settings (only for HP Designjet T1200).
