HP 4320t Mobile Thin Client - Overview
Product description
Product features
Feature
  • Mobile Intel HM57 Express Chipset
Processors1
  • Intel Celeron P4500 Processor (1.8 GHz, 2MB L3 cache)2
Memory3
Standard:
  • DDR3 PC3-10600 SDRAM (1333 MHz)4
  • Two SODIMM slots supporting dual-channel memory
  • 1024MB and 2048MB SODIMMs
  • Standard memory up to 4096MB
Dual-channel:
  • Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Graphics
Intel HD Graphics Microsoft DirectX 9 capable
Display5
Internal:
  • 13.3-inch diagonal LED-backlit HD anti-glare (1366 x 768 resolution)
  • Optional HP Privacy Filter
External:
  • Up to 32-bit per pixel color depth
  • VGA port supports resolutions up to 1600 x 1200 at 75 Hz, and lower resolutions at up to 100 Hz.
  • HDMI port supports direct connection to high-definition displays with up to 1920 x 1080 resolution and 7-channel audio with one convenient cable (not included).
Keyboard
  • The HP spill-resistant keyboard is designed using a Mylar film that minimizes the risk of damage to sensitive components underneath. The 101/102-key compatible keyboard features a full-pitch key layout with desktop keyboard features, such as the isolated inverted-T cursor control keys, editing keys, both left and right control and alt keys, and 12 function keys. US and International key layouts are available. Other features include hotkeys for instant access to power conservation and brightness, and 19.05 x 19.05 mm key pitch (center-to-center spacing).
Pointing device
ClickPad with left and right ClickPad buttons
Expansion card slots
  • ExpressCard/34 slot: Supports ExpressCard/34 (34 mm x 75 mm x 5 mm) card sizes
  • Media Card Reader: Supports SD (Secure Digital), MMC (MultiMedia Card), Memory Stick, Memory Stick Pro, Memory Stick Duo6, xD-Picture card
Storage
  • Internal storage device: 2GB or 4GB Solid State Module
  • Optional fixed optical drive: DVD-ROM Drive
Power supply
  • External 65-watt Smart AC adapter
Battery
Primary Battery:
  • HP 9-cell (93 WHr) Li-Ion battery
  • HP 6-cell (47 WHr) Li-Ion battery
1: Processor speed denotes maximum performance mode; processors will run at lower speeds in battery optimization mode.
2: Intel's numbering is not a measurement of higher performance.
3: Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If you mix memory speeds, the system will perform at the lower memory speed. Full availability of 4GB or more of memory requires Windows Vista Business 64-bit or Linux. With Windows 32-bit operating systems, the amount of usable memory is dependent upon your configuration, so that above 3GB all memory may not be available due to system resource requirements.
4: Memory speed is processor dependent.
5: Resolutions are dependent upon monitor capability, and resolution and color depth settings.
6: Memory Stick Duo Adapters are required and sold separately. Inserting a Memory Stick Duo Card directly into your notebook could damage the memory card and/or notebook.
Software overview
Feature
Preinstalled:
  • Genuine Windows Embedded Standard 2009
Software (Preinstalled)
  • Enhanced Write Filter
  • File Based Write Filter
  • Internet Explorer 7
  • Windows Media Player 11
  • TeemTalk Emulation
  • Symantec Endpoint Security
  • Microsoft Remote Desktop Protocol (RDP) 6.1
  • Microsoft Firewall
  • Citrix XenApp 11
  • VMWare View 4.0
  • WinDVD
Manageability solution
  • HP ThinState Tools
  • HP Device Manager
  • HP Client Automation
  • Altiris Deployment Solution1
HP Virtual Client essentials
  • HP Remote Desktop Protocol Enhancements
  • HP Remote Graphics Software (RGS)
Additional software available from the web
  • .NET Framework 2.0
  • Universal Print Driver (UPD)
  • PDF Complete
  • Citrix XenDesktop
  • Broadcom Wireless Utility
1: The Altiris Deployment Solution software is pre-installed but users must purchase a software license to activate the software. Click here to purchase a license to the Altiris Deployment Solution software.
Disclaimer: The above web link will take you outside the HP website. HP does not control and is not responsible for the information located outside the HP website.
