HP Pavilion Slimline s5560f Desktop PC Product Specifications
WW637AA
Introduction date
07-May-2010
Country/region sold in:
  • United States
  • Canada
Base processor
Phenom II X4-830 (D) 2.8 GHz (95W)
  • 4000 MHz HyperTransport 3.0
  • Socket AM3
AMD 760G
Motherboard
  • Manufacturer: Foxconn
  • Motherboard Name: H-Alpinia-RS780L-uATX
  • HP/Compaq motherboard name: Alpinia-GL8
Power supply
  • 220W (100V-240V)
Memory
Component
Attributes
Memory Installed
6 GB
Maximum allowed
16 GB (4 x 4 GB) (64-bit OS)
4 GB* (4 x 1 GB) (32-bit OS)
*Actual available memory may be less
Speed supported
PC3-10600 MB/sec
Type
240 pin, DDR3
  • 1 TB SATA 3G (3.0 Gb/sec)
  • 5400 rpm
SuperMulti Blu-ray Player with LightScribe Technology drive
  • Interface: SATA
  • Data buffer memory: 2 MB minimum
  • LightScribe: yes
  • Disc diameter: 120 mm
  • Write and read speeds for supported formats and disc types are shown in this table:
Formats/Disc types
Write speeds
Read speeds
Storage capacity
Blu-ray Disc
BD-ROM SL
NA
up to 6X
up to 25 GB
BD-ROM DL
NA
up to 4.8X
up to 50 GB
BD-R SL
not supported
up to 6X
up to 25 GB
BD-R DL
not supported
up to 4.8X
up to 50 GB
BD-RE SL
not supported
up to 2.3X
up to 25 GB
BD-RE DL
not supported
up to 2X
up to 50 GB
HD DVD
not supported
DVD
DVD-ROM SL
NA
up to 16X
up to 4.7 GB
DVD-ROM DL
NA
up to 8X
up to 8.5 GB
DVD+R SL
up to 16X
up to 12X
up to 4.7 GB
DVD+R DL
up to 4X
up to 8X
up to 8.5 GB
DVD+RW SL
up to 8X
up to 10X
up to 4.7 GB
DVD+RW DL
not supported
DVD-R SL
up to 16X
up to 12X
up to 4.7 GB
DVD-R DL
up to 4X
up to 8X
up to 8.5 GB
DVD-RW SL
up to 6X
up to 10X
up to 4.7 GB
DVD-RW DL
not supported
DVD-RAM
up to 5X
up to 5X
up to 4.7 GB
CD
CDROM
NA
up to 40X
up to 700 MB
CDR
up to 40X
up to 40X
up to 700 MB
CDRW
up to 24X
up to 40X
up to 700 MB
CD-DA
NA
up to 32X
up to 700 MB
Video CD
NA
up to 10X
up to 700 MB
Wireless
802.11 b/g/n PCI express wireless half-length mini card
Video Graphics
Radeon HD5450
  • 512 MB VDDR3 memory
  • I/O Ports: HDMI, DVI-I (single-link only), and VGA (using included DVI-to-VGA adapter)
Television
ATSC/NTSC/QAM PCI Express x1 TV tuner card (with IR)
Sound/Audio
High Definition 8-channel audio
  • ALC 888S-VD chipset
Network (LAN)
Integrated 10/100 Base-T networking interface
Memory card reader
  • Supports the following cards:
    • Secure Digital (SD)
    • MultiMediaCard (MMC)
    • Secure Digital High Capacity (SDHC)
    • MultiMediaCard Plus (MMC Plus)
    • xD media (xD)
    • Memory Stick (MS) and Memory Stick Pro (MS-Pro)
External I/O ports
I/O ports on the front panel
Port type
Quantity
6-in-1 card reader
One
USB
Two
Headphone
One
Passive IR receiver
One
I/O ports on the back panel
Port type
Quantity
S/PDIF digital audio output
One
VGA
One (disabled due to the installation of a graphics card)
DVI
One
USB 2.0
Four
LAN
One
Audio (side speaker out, rear speaker out, center/subwoofer-out , line-in, line-out, microphone)
One Each
Slot type
Quantity
PCI Express x16
One (None available)
PCI Express x1
PCI Express x1 minicard socket
Drive bays
Bay type
Quantity
13.33 cm (5.25 inch) external
8.89 cm (3.5 inch) internal
Keyboard and mouse
  • HP wireless keyboard
  • Quebec Keyboard Kit (French Canada only)
  • HP wireless mouse
Remote Control
  • USB infrared remote control
  • Remote control expansion card with IR ports
  • IR emitter cable to transmit codes to a set top box
HP provides basic support for software that comes with the computer. For in-depth feature assistance, refer to the help section in the software or on the software vendor's Web site.
Software titles that shipped with PC
Software Category
Software Title
Operating System
  • Microsoft Windows 7 Home Premium (64-bit)
CD/CD-RW/DVD/DVD+RW
  • HP MediaSmart DVD
  • Windows DVD Maker
  • CyberLink DVD Suite 6
Entertainment, Music & Games
  • HP Games
  • HP MediaSmart Software Suite
Productivity
  • Microsoft Works 9
  • Microsoft Office Home and Student Edition 2007 Trial
  • Windows Live Essentials (not for Canada)
Security
  • Norton Internet Security 2010 (60-day security update subscription)
  • Norton Online Backup (30-day trial)
Support
  • HP Advisor
  • HP Hardware Diagnostic Tools
  • HP Help & Support Center
  • HP Support Assistant
Recovery
  • HP Recovery Manager
Internet Solutions
  • Microsoft Internet Explorer
