HP Photosmart Premium Fax All-in-One Printers (C410a, C410b, C410c, C410d, C410e) - Setting up the All-in-One (Hardware)
  • Unpack the product
  • Adjust the control panel display
  • Install the document feeder tray
  • Install the control panel faceplate
  • Connect the power cord and adapter
  • Connect the phone cord
  • Turn on the power
  • Select the language and country/region
  • Install the cartridges
  • Load paper
  • Align the printheads
Follow these steps in order.
  1. On the rear of the product, remove the cardboard that secures the two-sided printing accessory (if installed).
    Figure : Remove cardboard from the two-sided printing accessory
    Illustration: Remove cardboard from the two-sided printing accessory.
  2. Remove the cardboard restraint from the top of the product.
  3. Grasp the access handles on the sides of the product to open the cartridge door.
    Figure : Open the cartridge door
    Illustration: Open the cartridge door.
  4. Remove the blue tape that holds the carriage restraint in place, slide the carriage to the left, and then remove the plastic restraint from the carriage.
    Figure : Remove the tape and carriage restraint
    Illustration: Remove the tape and carriage restraint.
  5. Close the cartridge door.
    Figure : Close the cartridge door
    Illustration: Close the cartridge door.
Step two: Adjust the control panel display
Adjust the control panel display, and then remove its protective film.
Step three: Install the document feeder tray
Install the document feeder tray into the automatic document feeder.
Line up the tabs on the edges with the slots in the product. Insert the tabs into the slots until they snap into place.
Figure : Install the document feeder tray
Illustration: Install the document feeder tray.
Step four: Install the control panel faceplate
The control panel faceplate might already be installed. If it is not installed follow these steps.
  1. Position the faceplate over the buttons on the product, and then press down firmly on all the edges of the faceplate until it snaps into place.
    Figure : Install the control panel faceplate
    Illustration: Install the control panel faceplate.
  2. Make sure that all buttons are visible and not blocked.
If you need to remove the control panel faceplate, pull up on the right edge of the faceplate.
Step five: Connect the power cord and adapter
  1. Connect the adapter to the rear of the product.
  2. Plug the power cord into the power adapter.
  3. Plug the other end of the power cord into an electrical outlet.
      Figure : Connect the power cord and adapter
      Illustration: Connect the power cord and adapter.
    1. Plug the power module into the product
    2. Plug the power cord into the power module
    3. Plug the power cord into the wall outlet
Step six: Connect the phone cord
Follow these steps if you plan to use the product fax.
Connect one end of the supplied phone cord to the port labeled 1-LINE on the rear of the product, and then connect the other end to a telephone jack.
Figure : Connect the phone cord
Illustration: Connect the phone cord to the back of the product and to the wall.
Step seven: Turn on the power
Press the Power button () to turn on the product.
Figure : Press the power button
Illustration: Press the power button.
Step eight: Select the language and country/region
  1. If prompted on the control panel display, press the Arrow buttons to select your language, and then press OK to confirm the selection.
    Figure : Press the Arrow buttons to select your language
    Illustration: Select the language.
  2. Press the Arrow buttons to select your country/region, and then press OK to confirm the selection.
Step nine: Install the cartridges
  1. Grasp the access handles on the sides of the product to open the cartridge door.
  2. Remove the new cartridge from its packaging, and then pull the orange tab straight back to remove the plastic wrap.
    Figure : Remove the plastic wrap
    Illustration: Remove the plastic wrap from the cartridge.
  3. Twist the orange cap counterclockwise to snap it off.
    Figure : Remove the orange cap
    Illustration: Remove the orange cap.
  4. Slide the new cartridge into its empty slot until it clicks into place and is seated firmly in the slot. Make sure that you insert the cartridge into the slot that has the same shape icon and color shown on the cartridge.
    Figure : Insert the cartridge
    Illustration: Insert the cartridge.
  5. Press down on the cartridge until it clicks firmly into place.
    Figure : Press the cartridge into place
    Illustration: Press the cartridge into place.
  6. Repeat these steps to install the other cartridges.
    Figure : Repeat steps to install other cartridges
    Illustration: Cartridges installed.
  7. Close the cartridge door.
Step ten: Load paper
Follow these steps to load paper in the product.
The following video demonstrates the steps to load paper in the product.
  1. Raise the output tray, and then slide the paper width guide outward.
    Figure : Lift the output tray and slide the paper width guide outward
    Illustration: Lift the output tray and slide the paper width guide outward.
  2. Load a stack of plain white paper into the input tray.
    Figure : Slide the stack of paper in the tray
    Illustration: Slide the stack of paper  in the tray.
  3. Slide the paper width guide inward until it stops at the edge of the paper.
    Figure : Slide the paper width guide inward
    Illustration: Slide the paper width guide inward
  4. Lower the output tray, and then pull the tray extender outward as far as it will go. Flip up the paper catch at the end of the tray extender.
    Figure : Lower the output tray and pull out the tray extender and paper catch
    Illustration: Lower the output tray and pull out the tray extender and paper catch.
Step eleven: Align the printheads
  1. On the control panel, press OK, and then wait while the product prints an alignment page.
  2. After the alignment page prints, press OK. Discard or recycle the alignment page.
