A 'Carriage Jam' or '0X610000F6' Message Displays for HP Photosmart Plus e-All-in-One (B210a, B210b, B210c, and B210e) Printers
Issue
A 'Carriage Jam: Clear Carriage Jam' or '0X610000F6' message displays on the product control panel. The following symptoms might accompany the error message:
  • A 'Carriage Jam' message might also display on the computer in Windows.
  • The carriage might be stuck on either side or in the middle of the product.
Video of clearing a carriage jam
View the following video or choose one of the topics below to learn what to do when a 'Carriage Jam: Clear Carriage Jam' or '0X610000F6' message displays on the control panel.
The following video demonstrates how to clear a carriage jam.
This video shows the HP Photosmart Plus e-All-in-One (B210a) printer. The outside of the printer might not look the same as your printer, but the steps are the same.
If you have trouble viewing the video or to view the video in a different size, click here to play the video on YouTube.
How to use the solutions in this document
To resolve the issue, try each solution in this document in the order presented.
IMPORTANT: Each time you try a solution, try to print a self-test report to determine if the hardware is functioning correctly. To print a self-test report, use the steps in the following table, or view the video following the table
How to print a self-test report
  1. Load plain white paper in the input tray.
  2. On the product control panel, touch the Setup icon ().
  3. Touch Tools.
  4. Touch Printer Status Report. The product prints the report.
Video of printing a self-test report
The following video demonstrates how to print a printer status report.
Refer back to the steps in the table or view the video after attempting each solution.
Solution one: Turn the All-in-One off and on again
  1. Press the Power button () to turn off the product. If the product does not turn off, continue to the next solution.
  2. Wait 60 seconds.
  3. Press the Power button () to turn the product on.
    The product might go through a warm-up period that might last up to two minutes. The product lights might flash and the carriage might move. Wait until the warm-up period completes before you continue.
  • If these steps resolved the issue, and the test page prints, there is no need to continue troubleshooting.
  • If the issue persists, continue with the next solution.
  • If the test page does not print, continue with the next solution.
Solution two: Clear any jammed paper
Jammed paper can cause the carriage to stall. Follow these steps to clear any jammed paper.
Step one: Remove any loose paper
Remove any loose sheets of paper from the input tray and the output tray.
Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism.
Step two: Clear the paper jam from the rear of the All-in-One
Use the following steps to check for and remove jammed paper from the rear of the product.
Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product.
  1. Disconnect the USB cable from the rear of the product.
  2. Press the Power button () to turn off the product.
  3. Disconnect the power cord from the rear of the product.
  4. Press in the tab on the left side of the rear access door, and then pull the door away from the product to remove it.
    Figure : Remove the rear access door
    Illustration of removing the rear access door
  5. Gently remove any jammed paper or bits of torn paper from the rollers inside the product. Use both hands to pull out any whole sheets of paper to avoid tearing them.
    Figure : Remove the jammed paper
    Photograph of removing jammed paper
    Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur.
    Figure : Remove torn scraps of paper
    Illustration of removing scraps of paper
  6. Check the rollers on the rear access door. Make sure that the rollers are not missing, that they turn easily, and that they are springy when you press them. If the rollers are damaged, replace the door.
    Figure : The rollers in the rear access door
    Photograph of the rollers in the rear access door
  7. Reattach the rear access door. Gently push the door forward until it snaps into place.
    Figure : Reattach the rear access panel
    Illustration of reattaching the rear access door
  8. Reconnect the power cord to the rear of the product.
  9. Press the Power button () to turn on the product.
Step three: Clear the jam from the front of the All-in-One
  1. If the product is not turned off, press the Power button () to turn it off.
  2. Disconnect the power cord from the rear of the product.
  3. Without opening the cartridge access door, raise the output tray, and then check the input tray for any jammed paper.
    Figure : Raise the output tray
    Graphic: Raise the output tray
  4. Remove any jammed paper from the input tray, and then lower the output tray.
  5. Open the cartridge access door.
    Illustration of opening the cartridge access door
  6. Manually move the carriage to one side of the product.
      warning:
    Do not reach into the product when it is on and the carriage is stuck. Always turn the product off before you remove any jam.
  7. If there is paper jammed in the product, gently remove the paper through the top of the product.
    If the paper tears when you remove it, check for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams might occur.
  8. Close the cartridge access door.
    Figure : Close the cartridge access door
    Illustration of closing the cartridge access door
  9. Reconnect the power cord to the rear of the product.
  10. Press the Power button () to turn on the product.
Step four: Print a self-test report
Print a self-test report. See the section on how to use these solutions at the beginning of this document.
Solution three: Make sure that the carriage moves freely
Use the following steps to check that the carriage can move freely in the product.
Step one: Check the carriage path
  1. If the product is not turned on, press the Power button () to turn it on.
  2. Open the cartridge access door.
    The carriage might try to move into the access area. If it does, allow it to move to that position.
  3. With the product turned on, disconnect the power cord from the rear of the product.
  4. Unplug the power cord from the power source or electrical outlet.
      warning:
    You must unplug the power cord to move the carriage by hand and reset the paper feed mechanism without the risk of electrical shock.
  5. Check for any paper or objects that might be restricting the carriage.
    Figure : Example of paper that could be restricting the carriage
    Illustration of paper in the carriage path that could restrict the carriage
  6. Remove any paper or objects you find.
  7. Reach inside the product through the cartridge access door, and then manually move the carriage.
    • If the carriage is stuck on the right side, move the carriage to the left side of the product.
    • If the carriage is stuck on the left side, move the carriage to the right side of the product.
    • If the carriage is stuck in the middle, move the carriage to the right.
  8. Make sure that the carriage can move freely across the width of the product by gently pushing the carriage to the left, and then to the right.
  9. Close the cartridge access door.
  10. Reconnect the power cord to the rear of the product.
  11. Plug the power cord back into the power source or electrical outlet.
  12. Press the Power button () to turn on the product.
Solution four: Remove and reinstall the cartridges
Improper placement or installation of the cartridges can cause the product to indicate a carriage jam error. Follow these steps to remove and then reinstall the cartridges.
Step one: Remove the cartridges
  3. Press the tab on each cartridge, and then remove each cartridge from its slot.
    Figure : Remove the cartridges
    Illustration of removing the cartridges
Step two: Reinstall the cartridges
  1. Slide each cartridge into the correct slot until it clicks into place. Make sure that you insert each cartridge into the slot with the matching color shaped icon.
    Figure : Install the cartridges
    Illustration of installting the cartridges
  2. Close the cartridge access door.
Step three: Print a self-test report
Solution five: Plug the product directly into a wall outlet
  1. Disconnect the power cord from the rear of the product.
  2. Disconnect the power cord from any power strip or surge suppressor, and then plug it directly into the wall outlet.
  3. Reconnect the power cord to the rear of the product.
  4. Press the Power button () to turn on the product.
  5. Try to print a self-test report. See the steps on how to print a self-test report at the beginning of this document.
    If the product prints when plugged directly into a wall outlet, the power strip or surge suppressor might not be allowing enough voltage to reach the product.
Solution six: Perform a power reset
Follow these steps to reset the product.
Step one: Perform a power reset
  1. With the printer turned on, disconnect the power cord from the rear of the printer.
  2. Unplug the power cord from the wall outlet.
  3. Wait at least 15 seconds.
  4. Plug the power cord back into the wall outlet.
  5. Reconnect the power cord to the printer.
  6. Turn the printer on.
Step two: Print a self-test report
  • If these steps resolved the issue, and the self-test report prints, there is no need to continue troubleshooting. Connect the USB cable to continue the print job.
  • If the issue persists, continue to the next step.
  • If the self-test report does not print, skip to the next solution.
Step three: Search for more information
If you are still experiencing issues, see the HP Product Support Home Page, and then search for another document that relates to the symptoms you are experiencing.
Right-click this link, Product Support Home Page, and then click Open in New Window.
If the page displays in the wrong country/region or language, click the Region - Language link in the upper right corner of your browser. Then you can select the correct country/region and language.
Solution seven: Service the product
Service or replace your HP product if the issue persists after completing all the preceding steps.
Go to Contact HP Customer Support to schedule a product repair or replacement. If you are in Asia Pacific, you will be directed to a local service center in your area.
To confirm your warranty status, go to HP Product Warranty Check. Repair fees might apply for out-of-warranty products.
