HP Officejet Pro 8500A (A910) e-All-in-One Printer Series - Inserting a Memory Card or USB Flash Drive
Use the information and instructions in this document as a reference when inserting a compatible memory card or Universal Serial Bus (USB) flash drive into the product.
Inserting the memory card or USB flash drive
Follow these steps to insert a memory card or USB flash drive into the product.
Method one: Insert the memory card
Never insert more than one memory card at a time. Doing so can damage the files on the memory cards.
  1. Remove the memory card from the camera.
  2. Identify the type of memory card you have.
    Multimedia cards
    Memory sticks
    Illustration of multimedia cards
    Illustration of memory sticks
  3. In the lower right corner of the product, find the memory card slot that is compatible with your memory card.
      Figure : Memory card slot locations
      Illustration of the memory card slot locations
    1. Pict-Bridge-enabled USB port
    2. Secure Digital, Micro Secure Digital (requires adapter), MultiMediaCard Mobile (requires adapter)
    3. Memory Stick, Memory Stick Duo, Memory Stick Pro
  4. If the product is not already on, press the Power button () to turn it on.
  5. Align the memory card vertically to match the card slot, and then hold the memory card so that the metal contacts face the paper tray.
    Inserting the memory card in any other way might damage the card and the product.
  6. Gently push the memory card into the memory card slot until it stops. The memory card does not insert all the way into the product. Do not try to force it.
  7. When the memory card is inserted correctly, the status light above the memory card slots flashes, and then remains solid green.
    Never attempt to remove a memory card while the product is accessing it. Doing so can damage files on the card. You can safely remove a card only when the status light next to the memory card slots is not blinking. Do not pull out a memory card while the light is flashing green.
Method two: Insert the USB drive
  1. If the product is not already on, press the Power button () to turn it on.
  2. Turn the USB drive so that the label faces upward and the contact faces the product.
    Inserting the USB drive in any other way might damage the card and the product.
  3. Gently push the USB flash drive into the USB port until it stops.
      Figure : The USB port
      Illustration indicating the USB port
    1. USB port
  4. Check the status light above the USB slot. When the USB drive is inserted correctly, the status light flashes, and then remains solid green.
