HP Compaq 6005 Pro Ultra-slim Desktop PC Product Specifications
Product description
HP Compaq 6005 Pro Ultra-slim Desktop PC is designed to deliver uncompromised results with energy efficiency features, and high-end capabilities.
Product features
Feature
AMD 785G chipset
Processor
AMD Sempron processors with HyperTransport technology:
  • AMD Sempron 145 processor (2.8 Ghz, 1MB L2 cache, HT bus 3.0)
AMD Athlon II Dual-Core processors with HyperTransport technology:
  • AMD Athlon II X2 220 processor (2.8 GHz, 2MB L2 cache, HT bus 3.0)
  • AMD Athlon II X2 B22 processor (2.8 GHz, 2MB L2 cache, HT bus 3.0)
  • AMD Athlon II X2 B24 processor (3.0 GHz, 2MB L2 cache, HT bus 3.0)
  • AMD Athlon II X2 B26 processor (3.2 GHz, 2MB L2 cache, HT bus 3.0)
  • AMD Athlon II X4 605e processor (2.3 GHz, 2MB L2 cache, HT bus 3.0)
Memory type supported
Un-buffered non-ECC DDR3 SDRAM
Maximum memory
8GB
Memory cards
  • HP 4GB PC3-10600 (DDR3 1333 MHz) SODIMM
  • HP 2GB PC3-10600 (DDR3 1333 MHz) SODIMM
  • 2.5-inch 160GB SATA 3.0 Gb/s hard drive (8MB cache, 7200 RPM, NCQ Smart IV)
  • 2.5-inch 250GB SATA 3.0 Gb/s hard drive (8MB cache, 7200 RPM, NCQ Smart IV)
Solid state drive
  • 64GB solid state drive
  • 80GB solid state drive
Optical drive
  • HP slim DVD-ROM drive
  • HP slim SuperMulti lightScribe DVD writer drive
Removable storage
  • 250GB pocket media drive
  • Secure digital (SD) HC reader
Network interface card
Broadcom NetXtreme Gigabit ethernet BCM 5761 (integrated on system board)
Wireless
HP 802.11 b/g/n wireless PCIe x1 half mini card (2x2)
Graphics
  • Integrated ATI Radeon HD 4200 graphics
    The AMD 785G chipset provides a Side Port memory interface for 128MB of dedicated frame buffer DDR3 memory with a device width of x16 for the integrated graphics chip.
  • HP DisplayPort to VGA adapter
  • HP DisplayPort to DVI-D adapter
Audio
  • Integrated high definition audio with Realtek ALC261 codec (all ports are stereo)
  • Microphone and headphone front ports
  • Line-out and line-in rear ports
  • Multistreaming capable
  • Internal speaker
  • HP thin USB powered speakers (optional)
Input devices
Keyboard - Any one of the following:
  • HP PS/2 standard keyboard
  • HP USB standard keyboard
  • HP smartcard keyboard
  • HP USB PS/2 washable keyboard
  • HP USB mini keyboard
Mouse - Any one of the following:
  • USB 2-button laser mouse
  • PS/2 2-button optical scroll mouse
  • USB 2-button optical scroll mouse
Monitors
All HP monitors are supported that accept a graphics output provided by this PC. The LP3065 monitor can be supported by installing a graphics card that supports a dual-link DVI-D output.
Miscellaneous
  • HP TV tuner mini PCIe card
  • Tower stand
Power supply
135 W 87% efficient, active PFC (external power adapter)
Security
  • TPM 1.2 embedded security chip
  • HP desktop security lock kit (lock and cable)
  • HP chassis security kit
  • Security cable with Kensington lock
Ports
  • USB 2.0: 10 (4 front, 6 rear)
  • PS/2: 1 keyboard, 1 mouse
  • Video: VGA and DisplayPort for integrated graphics
  • DVI output: Available via HP DisplayPort to DVI-D adapter
  • Support for Multi-Monitor: 1 standard DisplayPort and 1 standard VGA
  • Audio (front): Microphone and headphone
  • Audio (rear): Input (supports microphone or line-input) and line-out
  • NIC (RJ-45): 1
Electrical specifications
Feature
Power supply
Operating voltage range
100-240 V ac
Rated voltage range
115/230 V
Rated line frequency
50/60 Hz
Operating line frequency range
47-63 Hz
Rated input current
2.4 A
Technical specifications
Feature
AMD 785G chipset
Processor
Maximum memory
8GB
Memory cards
Solid state drive
Optical drive
Removable storage
Wireless
Graphics
Audio
  • Internal speaker
Input devices
Monitors
Miscellaneous
  • Tower stand
Security
Ports
  • Audio (rear): Input (supports microphone or line-input), line-out
  • NIC (RJ-45): 1
Physical specifications
Feature
Chassis dimensions (H x W x D)
6.6 x 25.15 x 25.4 cm (2.6 x 9.9 x 10 in)
Optional tower stand dimensions (H x W x D)
2.72 x 12.49 x 16.99 cm (1.07 x 4.92 x 6.69 in)
System volume
4219.67 cu cm (257.5 cu in)
System weight (Configured with 1 hard drive, 1 optical drive, no diskette drive, and no PCI card)
3.07 kg (6.75 lb)
Shipping weight (Configured with 1 hard drive, 1 optical drive, no diskette drive, and no PCI card)
6.54 kg (14.42 lb)
Maximum supported weight (desktop orientation)
35 kg (77 lb)
Shipping box dimensions (H x W x D)
21.84 x 39.83 x 49.99 cm (8.60 x 15.68 x 19.68 in)
External power adapter dimensions (H x W x D)
17.02 x 6.60 x 3.81 cm (6.7 x 2.6 x 1.5 in)
External power adapter total cord length
3.9 m (12.8 ft)
Software/OS
Feature
One of the following:
Pre-installed
  • Genuine Windows 7 Professional Edition 32-bit
  • Genuine Windows 7 Professional Edition 64-bit
  • Windows XP Professional (available through downgrade rights from Genuine Windows 7 Professional)
  • Genuine Windows 7 Home Premium Edition 32-bit
  • Genuine Windows 7 Home Premium Edition 64-bit
  • Genuine Windows 7 Home Basic Edition 32-bit
  • Genuine Windows Vista Business Edition 32-bit
  • Genuine Windows Vista Home Basic Edition 32-bit
  • Windows XP Professional (available through downgrade rights from Genuine Windows Vista Business)
  • Novell SUSE Linux Enterprise Desktop 11
  • Free DOS
Supported
  • Genuine Windows Vista Business Edition 64-bit
  • Genuine Windows Vista Enterprise Edition 32-bit
  • Genuine Windows Vista Enterprise Edition 64-bit
Certified
  • Red Hat Enterprise Linux
Value-added software (on select models; not included with Free DOS)
  • HP Software Agent
  • HP Support Assistant
  • HP Systems Software Manager
  • HP Vision Diagnostics
  • HP Power Assistant
  • McAfee Total Protection Anti-Virus with 60 day trial Subscription
  • Roxio Creater Business (selected models)
  • Firefox-HP Virtual Browser
  • SRS Premium Sound Software for HP thin USB powered speakers (selected models)
  • Microsoft Office 2007 Basic/Personal/Professional/Small Business Edition
  • Integrated DASH 1.1 Manageability
  • Computrace Enabler for Desktops (selected countries)
    Requires HP LoJack Pro for ProtectTools for full functionality. Tracking and tracing subscription sold separately.
  • HP Skyroom (trial version)
  • Corel WinDVD (selected models)
  • Norton Online Backup
Environmental specifications
Feature
Temperature range
  • Operating: 10° to 35°C (50° to 95°F)
  • Non-operating: -30° to 60°C (-22° to 140°F)
Operating temperature is de-rated 1.0°C per 300 m (1000 ft) to 3000 m (10,000 ft) above sea level, no direct sustained sunlight. Maximum rate of change is 10°C/Hr. The upper limit may be limited by the type and number of options installed.
Relative humidity
  • Operating: 10% to 90% (non-condensing at ambient)
  • Non-operating: 5% to 95% (non-condensing at ambient)
Maximum altitude (unpressurized)
  • Operating: 3048 m (10,000 ft)
  • Non-operating: 9144 m (30,000 ft)
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
