Document ID: c02130182
Version: 1
HP EliteBook 8440p Notebook PC and HP EliteBook 8440w Mobile Workstation System BIOS Update F.0B
Release date : 28-Apr-2010
Last updated : 18-Jun-2010
รายละเอียดการเปลี่ยนแปลง
New features:
  • Updated to the latest Intel Microcode to support the Intel Core i3-450M, Core i3-370M, Core i3-350M, Core i5-520M, Core i5-540M, and Core i7-620M K-0 Stepping Processors.
  • Added an option to disable booting from USB devices, a notebook expansion bay, or a docking upgrade bay.
  • Added an "Auto Power-On" feature, which enables the notebook to automatically power itself on at a specific date and time.
Field issue fixes:
  • Improved hard drive performance in IDE mode and when the notebook is running under the Microsoft Windows XP operating system.
  • Fixed a slow boot issue with external floppy drives.
  • Fixed an issue where the notebook does not boot from a SanDisk USB Flash Drive that has the SanDisk U3 software installed.
REASON FOR CHANGE
To implement changes under "Details of Change."
IMPACT OF CHANGE
This system BIOS update is required for the HP EliteBook 8440p Notebook PC and the HP EliteBook 8440w Mobile Workstation, and it is required to support new Intel K-0 stepping processors. HP highly recommends users do not revert back to system BIOS versions F.0A or older. Flashing a BIOS version prior to F.0B after updating the BIOS version to F.0B will cause the system to not boot and will render the system board useless.
Components affected:
DATE OF CHANGE
Effective date : 30-Jun-2010
Hardware platforms affected : HP EliteBook 8440p Notebook PC, HP EliteBook 8440w Mobile Workstation
