HP Deskjet 3050 Printers- Paper Jam Error
This document is for HP Deskjet 3050 and 3054 All-in-One printers.
During printing, the HP printer stops feeding pages, and the error message Paper Jam. Clear jam, and then press OK displays on the printer control panel. The Power light and the Attention light on the control panel might blink.
Video overview
The following video demonstrates how to clear a paper jam.
The video shows the HP Deskjet 3050. The outside of the printer might not look the same as your printer, but the steps are the same.
Step 1: Look for jammed paper
Paper jams can occur in multiple areas of the printer. If you cannot find the paper jam in one area, continue to the next area until you locate the jam.
If you have checked and removed any jammed paper from each printer area and the error persists, continue to the next step.
Step 2: Make sure the carriage can move freely
Make sure the carriage moves freely across the width of the printer.
  1. Turn on the printer, if it is not already on.
  2. Open the cartridge access door.
    The carriage moves to the center of the printer.
  3. Wait until the carriage is idle and silent before you continue.
  4. With the printer turned on, disconnect the power cord from the rear of the printer.
  5. Unplug the power cord from the power source or electrical outlet.
      warning:
    You must unplug the power cord to move the carriage by hand and reset the paper feed mechanism without the risk of electrical shock.
  6. Check for any paper or objects that might be restricting the carriage, and then remove any paper or objects that you find.
    If the paper tears when you remove it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the printer. If pieces of paper remain in the printer, more paper jams can occur.
  7. Reach inside the printer through the ink cartridge access door, and then manually move the carriage.
    • If the carriage is stuck on the right side of the printer, move the carriage to the left side of the printer.
    • If the carriage is stuck on the left side of the printer, move the carriage to the right side of the printer.
    • If the carriage is stuck in the middle of the printer, move the carriage to the right side of the printer.
  8. Remove any loose paper or obstructions found.
  9. Make sure the carriage can move freely across the width of the printer. Firmly push the carriage to the left side of the printer, and then to the right side.
  10. Close the ink cartridge access door.
    Close the cartridge access door
  11. Reconnect the power cord to the rear of the printer, and then turn on the printer.
Try to print. If the error persists, continue to the next step.
Step 3: Clean the paper feed rollers
Dust, paper fiber, and other debris might accumulate on the paper feed rollers and cause paper jams and paper feed issues. Clean the rollers inside the printer, and then try to print again.
  1. Turn off the printer, and then disconnect the power cord.
      warning:
    Disconnect the power cord before reaching inside the printer to avoid risk of injuries or electric shock.
  2. Raise the input tray.
    Raising the input tray
  3. Look down through the open input tray and find the gray paper pick rollers. You might need a flashlight to illuminate the area.
    Photo: paper pick rollers
  4. Dampen a long cotton swab with bottled or distilled water, and then squeeze any excess water from the swab.
  5. Press the swab against the rollers and rotate them upward with your fingers. Apply a moderate amount of pressure to remove dust or dirt buildup.
  6. Allow the rollers to dry for 10 or 15 minutes.
  7. Reconnect the power cord to the rear of the printer, and then turn on the printer.
Step 4: Reset the printer
Sometimes a paper jam error persists even though there is no jammed paper (false paper jam). Reset the printer, which might clear a false paper jam error, and then try to print again.
  1. With the printer turned on, disconnect the power cord from the printer.
  2. Unplug the power cord from the power source.
  3. Wait 60 seconds.
  4. Reconnect the power cord to a wall outlet and to the printer.
    HP recommends plugging the printer directly into a wall outlet.
Step 5: Service the printer
Service or replace your HP product if the issue persists after completing all the preceding steps.
Go to Contact HP Customer Support to schedule a product repair or replacement. If you are in Asia Pacific, you will be directed to a local service center in your area.
To confirm your warranty status, go to HP Product Warranty Check. Repair fees might apply for out-of-warranty products.
