HP Color LaserJet CM1312 MFP Series Product - Print on both sides of the page (duplex printing)
Issue:
How to print on both sides of the page (duplex printing).
Solution
Use automatic duplex printing
  1. Insert enough paper into one of the trays to accommodate the print job. If you are loading special paper such as letterhead, load it in one of the following ways:
    • For tray 1, load the letterhead paper face-up with the bottom edge feeding into the printer first.
    • For all other trays, load the letterhead paper face-down with the top edge at the back of the tray.
  2. On the File menu, click Print.
  3. Open the Layout pop-up menu.
  4. Next to Two-Sided, select either Long-Edge Binding or Short-Edge Binding.
  5. Click Print.
Print on both sides manually
  1. Insert enough paper into one of the trays to accommodate the print job. If you are loading special paper such as letterhead, load the letterhead paper face-up with the bottom edge feeding into the printer first.
    To avoid jams, do not load paper that is heavier than 105 g/m2 (28-lb bond).
  3. On the Finishing pop-up menu, select Manual Duplex.
  4. Click OK.
  5. Click Print. Follow the instructions in the pop-up window that appears on the computer screen before replacing the output stack into the tray for printing the second half.
  6. If prompted, press the appropriate control-panel button to continue.
