Compaq Evo n1000c Notebook PC - Removing and Replacing the TouchPad/TouchPad Button Boards
This document is provided to assist in removing and replacing the touchpad/touchpad button boards for the Compaq Evo n1000c Notebook PC.
Minimum skill level
The End-User must possess extensive product-specific knowledge and technical skill on how to service the system, and be familiar with the operating system.
Tools required
  • Torx #8 (T8) screwdriver
  • Small, Phillips-head (P1 and P0) screwdrivers
  • Small, smooth-tipped needlenose pliers (optional)
Parts required
The replacement part number will vary depending on the touchpad/touchpad button boards that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP.
Part Number
Requires Return
Hardware/plastics kit - Includes (l/r) hinge covers, display release, touchpad bracket, charger board shield, optical drive rails, PC card blank, connector cover, hard drive bracket, Mini PCI cover, memory expansion cover, battery bezel, rubber feet
285541-001 (Original)
No
Summary of instructions
To view a video demonstrating the procedure for removing the touchpad/touchpad button boards, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library) then select TouchPad/TouchPad Button Boards from the menu on the upper left hand side of the screen.
Click here to view the touchpad/touchpad button boards removal video (right-click on the link to open in a new window/tab).
Touchpad/touchpad button boards removal
  2. With the palm rest upside down, disconnect both ends of the TouchPad-to-TouchPad button board ribbon cable from the LIF connectors on the TouchPad and TouchPad button boards.
    Use care to prevent damaging the TouchPad-to-TouchPad button board ribbon cable.
  3. Remove the TouchPad-to-TouchPad button board ribbon cable.
  4. Remove the four T8-5 mm screws that secure the TouchPad bracket to the palm rest.
  5. Remove the TouchPad bracket from the palm rest.
  6. Remove the TouchPad button board from the palm rest.
  7. Remove the TouchPad board from the palm rest.
    If your notebook includes both a TouchPad and a pointing stick, perform the following steps to remove the TouchPad board, TouchPad button board, and pointing stick board:
    1. Push the locking bar out to unlock the pointing stick-to-TouchPad button board cable ZIF connector on the pointing stick board and disconnect the cable.
    2. Push the locking bar out to unlock the pointing stick-to-TouchPad button board cable ZIF connector on the TouchPad button board and disconnect the cable.
    3. Disconnect both ends of the TouchPad-to-TouchPad button board ribbon cable from the LIF connectors on the TouchPad and TouchPad button boards.
    4. Remove the TouchPad-to-TouchPad button board ribbon cable.
    5. Remove the five T8-5 mm screws that secure the TouchPad bracket to the palm rest.
    6. Remove the TouchPad bracket from the palm rest.
    7. Remove the pointing stick board from the palm rest.
    8. Remove the TouchPad board from the palm rest.
    9. Remove the TouchPad button board from the palm rest.
Touchpad/touchpad button boards replacement
  1. Replace the TouchPad board into the palm rest.
  2. Replace the TouchPad button board into the palm rest.
  3. Replace the TouchPad bracket into the palm rest.
  4. Replace the four T8-5 mm screws that secure the TouchPad bracket to the palm rest.
  5. Reconnect both ends of the TouchPad-to-TouchPad button board ribbon cable to the LIF connectors on the TouchPad and TouchPad button boards.
    • Use care to prevent damaging the TouchPad-to-TouchPad button board ribbon cable.
    • If your notebook includes both a TouchPad and a pointing stick, perform the following steps to replace the TouchPad board, TouchPad button board, and pointing stick board:
      1. Replace the TouchPad button board into the palm rest.
      2. Replace the TouchPad board into the palm rest.
      3. Replace the pointing stick board into the palm rest.
      4. Toe the TouchPad bracket into the palm rest and lay it flat.
      5. Replace the five T8-5 mm screws that secure the TouchPad bracket to the palm rest.
      6. Reconnect both ends of the TouchPad-to-TouchPad button board ribbon cable to the LIF connectors on the TouchPad and TouchPad button boards.
      7. Insert the pointing stick-to-TouchPad button board ribbon cable into the ZIF connector on the TouchPad button board.
      8. Push the locking bar in to lock the ZIF connector on the TouchPad button board.
      9. Insert the pointing stick-to-TouchPad button board ribbon cable into the ZIF connector on the pointing stick board.
      10. Push the locking bar in to lock the ZIF connector on the pointing stick board.
