    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP Photosmart e-All-in-One (D110a and D110b) Printers - Setting up the All-in-One (Hardware)
  • Unpack the All-in-One
  • Connect the power cord and adapter
  • Turn on power
  • Select the language and country/region
  • Install the cartridges
  • Load plain paper
  • Align the cartridges
Follow these steps in order.
  1. Lower both the paper tray and the cartridge door.
    Figure : Lower the paper tray
  2. Remove all packing material and protective film from the product.
    Figure : Remove the packing material
  3. Close the cartridge door.
    Figure : Close cartridge door
Step three: Connect the power cord and adapter
Do not connect the USB cable.
  1. Connect the power adapter to the back of the product.
  2. Connect the power cord to the power adapter.
  3. Connect the other end of the power cord to an alternating current (AC) power outlet.
Figure : Connect the power cord and adapter
Step four: Turn on power
Press the Power button () to turn on the product.
Figure : Press Power
Step five: Select the language/region
Follow the instructions on the control panel display to set the default language and country/region for the product.
  1. On the product control panel, press the Right Arrow () to select your language, and then press OK.
  2. Press the Right Arrow () to select Yes, and then press OK.
  3. Press the Right Arrow () to select your country/region, and then press OK.
  4. Press the Right Arrow () to select Yes, and then press OK.
Step six: Install the cartridges
Leave the product turned on and follow these steps to install the cartridges.
  1. Open the cartridge door. Make sure the carriage moves to the center. If it does not move to the center, turn the product off, and then turn it back on again.
    Figure : Open the cartridge door
  2. Remove the cartridges from their packaging, and then remove the pink protective tape from both cartridges.
    Do not touch the copper-colored contacts or re-tape the cartridges.
    Figure : Remove the pink tape
    Figure : Do not touch contacts
  3. Hold the cartridges with the label on top.
    Figure : Label on top
  4. Insert the tri-color cartridge into the left carriage slot and insert the black cartridge into the right carriage slot.
    Figure : Tri-color cartridge in the left slot
  5. Press the cartridges firmly into the carriage until they snap into place.
    Figure : Insert cartridges until they snap into place
  6. Close the cartridge door.
  7. Press OK to confirm the installation of genuine HP cartridges, when prompted.
Step seven: Load plain paper
  1. Pull out the tray extender, and then flip open the paper catch.
    Figure : Pull out tray extender
  2. Load paper in the input tray with the short edge forward and the print side down. Slide the stack forward until it stops.
    Figure : Load paper
    Make sure all the paper in the stack is the same size and type and free from rips, dust, wrinkles, and curled or bent edges.
  3. Slide the paper-width guide inward until it stops at the edge of the paper.
  4. Press OK.
Step eight: Align the cartridges
When you install a new cartridge, the product aligns the cartridges. You can also align the cartridges at any time using the product software. Aligning the cartridges helps produce high quality output.
  1. Follow the instructions on the control panel display to print the alignment page.
    Figure : Alignment page prints
  2. Lift the lid.
  3. Load the alignment page face down in the front right corner of the glass.
    Figure : Load alignment page
  4. Close the lid, and then press OK to complete the alignment.
Getting started with ePrint
Now you can stay connected and productive on the go with ePrint. ePrint lets you print directly to your ePrint-enabled HP printer using a smartphone, notebook, or other mobile device. For additional information related to setting up and using ePrint, click the link provided.
