Compaq Evo n610c Notebook PC - Removing and Replacing the Hard Disk Drive
This document is provided to assist in removing and replacing the hard disk drive for the Compaq Evo n610c Notebook PC.
Minimum skill level
Tools required
Small Phillips-head (P0 and P1) screwdrivers.
Parts required
The replacement part number will vary depending on the hard disk drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
40GB Hard drive (MultiBay)
265495-001 (Original)
Yes
30GB IDE hard disk drive - 4200 RPM, 2.5-inch form factor, 9.5 mm thick
257660-001 (Original)
Yes
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labeled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the hard disk drive, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Hard disk drive from the menu on the upper left hand side of the screen.
Click here to view the hard disk drive removal video (right-click on the link to open in a new window/tab).
Hard disk drive removal
  2. Remove the black 3 mm Phillips-head screw that secures the hard disk drive.
  3. Lift the plastic locking mechanism above the base enclosure.
  4. Pull the hard disk drive out of the bay by the locking mechanism and remove.
  5. Place the hard disk drive in a static dissipative bag.
Hard disk drive replacement
  1. Remove the hard disk drive from the static dissipative bag.
  2. Lift the plastic locking mechanism on the hard disk drive.
  3. Slide the hard disk drive into the bay and push it in until the connector is seated.
  4. Press down on the locking mechanism until it is flush with the base enclosure.
  5. Replace the black 3 mm Phillips-head screw.
