    Fix HP Printer issue on macOS
HP Scitex LX Printer Family - Remove a substrate preset
To remove a substrate preset from your printer, go to the HP Internal Print Server and select Substrate > Remove. Then select the category and type of the substrate you wish to remove from a list of removable substrates.
