HP Z200 Small Form Factor Workstation Specifications
Product description
The surprisingly nimble and dynamic HP Z200 Small Form Factor (SFF) Workstation delivers workstation performance in a form factor almost 1/3 the size of the Z200 minitower. Engineered specifically for crowded desks, cubicles, and space-constrained environments, the HP Z200 SFF proves that size does not equal power.
The HP Z200 SFF packs workstation performance and reliability into a streamlined, affordable design optimized for energy efficiency.
Product features
Feature
Intel PCH 3450
Super I/O controller
SMSC SCH5327, Rev B
Processor socket
Single LGA 1156
Processors
Quad-Core Intel Xeon Processor 3400 Series with Intel Nehalem Architecture:
  • Intel Xeon Processor X3430 2.40 GHz, 8MB cache, 1333 MHz memory, Quad-Core, HT, Turbo
  • Intel Xeon Processor X3440 2.53 GHz, 8MB cache, 1333 MHz memory, Quad-Core, HT, Turbo
  • Intel Xeon Processor X3450 2.66 GHz, 8MB cache, 1333 MHz memory, Quad-Core, HT, Turbo
  • Intel Xeon Processor X3460 2.80 GHz, 8MB cache, 1333 MHz memory, Quad-Core, HT, Turbo
  • Intel Xeon Processor X3470 2.93 GHz, 8MB cache, 1333 MHz memory, Quad-Core, HT, Turbo
Dual-Core Intel Clarkdale Processors:
  • Intel Pentium Processor G6950 2.8 GHz, 3MB cache, 1066 MHz memory, Dual-Core
  • Intel Core Processor i3-530 2.93 GHz, 4MB cache, 1333 MHz memory, Dual-Core, HT
  • Intel Core Processor i3-540 3.06 GHz, 4MB cache, 1333 MHz memory, Dual-Core, HT
  • Intel Core Processor i5-650 3.2 GHz, 4MB cache, 1333 MHz memory, Dual-Core, Turbo
  • Intel Core Processor i5-660 3.33 GHz, 4MB cache, 1333 MHz memory, Dual-Core, HT, Turbo
  • Intel Core Processor i5-670 3.46 GHz, 4MB cache, 1333 MHz memory, Dual-Core, HT, Turbo
Memory type supported
DDR3, UDIMM (Unbuffered), ECC and nECC
Memory expansion slots
4 DDR3 memory slots
Maximum memory
16GB
Memory
Custom to Order (CTO):
  • PC3-10600 DDR3-1333 ECC Unbuffered DIMMs CTO
    • 16GB (4 x 4GB) DDR3-1333 ECC Unbuffered RAM 1-CPU
    • 8GB (2 x 4GB) DDR3-1333 ECC Unbuffered RAM 1-CPU
    • 8GB (4 x 2GB) DDR3-1333 ECC Unbuffered RAM 1-CPU
    • 4GB (2 x 2GB) DDR3-1333 ECC Unbuffered RAM 1-CPU
    • 3GB (3 x 1GB) DDR3-1333 ECC Unbuffered RAM 1-CPU
    • 2GB (2 x 1GB) DDR3-1333 ECC Unbuffered RAM 1-CPU
    • 1GB (1 x 1GB) DDR3-1333 ECC Unbuffered RAM 1-CPU
    Two channels of DDR3 memory are supported. To realize full performance at least one DIMM must be inserted into each channel. The CPUs determine the speed at which the memory is clocked. If a 1066 MHz capable CPU is used in the system, the maximum speed the memory will run at is 1066 MHz regardless of the specified speed of the memory.
After Market Options (AMO):
  • PC3-10600 DDR3-1333 ECC Unbuffered DIMMs AMO
    • 4GB (1 x 4GB) DDR3-1333 ECC Unbuffered RAM
    • 2GB (1 x 2GB) DDR3-1333 ECC Unbuffered RAM
    Only unbuffered DDR3 DIMMs are supported.
Graphics
  • Intel HD Graphics
Professional 2D
  • NVIDIA Quadro NVS 295 256MB PCIe Graphics Card
Entry 3D
  • NVIDIA Quadro FX 380 LP 512MB PCIe Graphics Card
Monitors
  • HP ZR24w 24-inch S-IPS LCD Monitor
  • HP ZR22w 21.5-inch S-IPS LCD Monitor
  • HP LP3065 30-inch Widescreen LCD Monitor
  • HP LP2475w 24-inch Widescreen LCD Monitor
  • HP LP2275w 22-inch Widescreen LCD Monitor
  • HP DreamColor LP2480zx Professional Display
  • HP LP1965 19-inch LCD Monitor
  • HP LP2065 20-inch LCD Monitor
Screen size is measured diagonally.
Input devices
  • HP USB Laser Mouse
  • HP SpaceExplorer 3D USB Controller
  • HP USB 2-Button Optical Scroll Mouse
  • HP USB Standard Keyboard
  • HP PS/2 Optical Scroll Mouse
  • HP PS/2 Standard Keyboard
  • HP USB Optical 3-Button Mouse
  • HP USB Smart Card Keyboard
  • HP 2.4 GHz Wireless Keyboard and Mouse
Power supply
240 W wide-ranging, active Power Factor Correction, 89% Efficient
Technical specifications
Feature
System board form factor
BTX 21.2 mm x 26.7 mm
Intel PCH 3450
SMSC SCH5327, Rev B
Processor socket
Single LGA 1156
Processors
CPU bus speed
DMI
4 DDR3 memory slots
Maximum memory
16GB
Memory
Hard drives
  • 160GB SATA 7200 RPM 3 Gb/s 3.5-inch HDD
  • 160GB SATA 10000 RPM SFF in 3.5-inch Frame HDD
  • 250GB SATA 7200 RPM 3 Gb/s 3.5-inch HDD
  • 300GB SATA 10000 RPM SFF in 3.5-inch Frame HDD
  • 320GB SATA 7200 RPM 3 Gb/s 3.5-inch HDD
  • 500GB SATA 7200 RPM 3 Gb/s 3.5-inch HDD
  • 1000GB (1TB) SATA 7200 RPM 3 Gb/s 3.5-inch HDD
Optical and removable storage
  • HP 16X DVD-ROM SATA Drive
  • HP 16X DVD+-RW SuperMulti SATA Drive
  • HP 22-in-1 Media Card Reader Kit
  • HP Blu-ray Writer
  • HP 22-in-1 3.5 JackBlack Media Card Reader with 1394a
Controller cards
HP FireWire/IEEE 1394a PCI Card
Graphics
  • Intel HD Graphics
Professional 2D
Entry 3D
Power supply
Multimedia and audio devices
  • HP Thin USB Powered Speakers
  • Integrated Intel/Realtek HD ALC261 Audio
Racking and physical security
  • Security cable with Kensington Lock
  • HP Solenoid Hood Lock and Hood Sensor
Networking and communications
Broadcom (5761) NetXtreme Gigabit Ethernet Plus NIC
  • Connector: RJ-45
  • Controller: Broadcom 5761 PCI-Express LAN Controller
  • Memory: 8 MB NVRAM serial Flash
  • Data Rates Supported: 10/100/1000 Mb/s
  • Compliance: IEEE 802.1P, 802.1Q, 802.2, 802.3, 802.3AB, 802.3u, and 802.3x
Intel Gigabit CT Desktop NIC
  • Connector: RJ-45
  • Controller: Intel WG82574L Gigabit Ethernet Controller
  • Memory: Integrated Dual 48K configurable transmit receive FIFO Buffers
  • Compliance: IEEE 802.1P, 802,1Q, 802.2, 802.3, 802.3AB and 802.3u compliant, 802.3x flow control
Other hardware
Monitors
Input devices
Miscellaneous
  • HP Power Cord Kit
  • HP Workstation Mouse Pad
  • HP Serial Port Adapter
  • HP ENERGY STAR 5.0 Enabled Configuration
  • HP Parallel Port Adapter Kit
Physical specifications
Feature
Chassis dimensions (W x D x H)
  • Standard desktop orientation: 100 mm x 338 mm x 381 mm (3.95 in x 13.3 in x 15.0 in)
  • Optional small form factor tower orientation (excluding stand dimension): 338 mm x 100 mm x 381 mm (13.3 in x 3.95 in x 15.0 in)
  • System weight1: 7.6 kg (16.72 lbs)
  • Shipping weight1: 8.1 kg (17.86 lbs)
  • Max supported weight (desktop orientation): 35 kg (77 lb)
Exact weights depend upon configuration.
1: Configured with one hard drive, one optical drive and one NVIDIA Quadro NVS 295 low profile graphics card.
Software/OS
Feature
  • HP Linux Installer Kit
  • Genuine Windows 7 Professional 32-bit
  • Red Hat Linux Workstation 5 Drop In Box OS
  • Genuine Windows 7 Professional 32-bit with downgrade to Windows XP Professional 32-bit custom installed
  • Genuine Windows 7 Professional 64-bit
  • Novell SLED 11 Linux
  • Genuine Windows 7 Professional 64-bit with downgrade to Windows XP Professional x64 custom installed
Applications
  • Intervideo WinDVD with DVD player
  • Microsoft Office 2007 Small Business Edition
  • Microsoft Office 2007 Trial Edition
  • PDF Complete - Trial Edition
  • Roxio Easy Media Creator (CD or DVD burner)
  • HP Client Manager Software v6.2 (optional download)
  • HP SkyRoom Software
  • HP Support Assistant
Environmental specifications
Feature
Temperature
Operating: 5° to 35°C (40° to 95°F)
Non-operating: -40° to 60°C (-40° to 140°F)
Humidity
Operating: 8% to 85% RH, non-condensing
Non-operating: 8% to 90% RH, non-condensing
Maximum altitude
Operating: 3,000 m (10,000 ft)
Non-operating: 9,100 m (30,000 ft)
Dynamic (new)
Shock
  • Operating:
    1/2-sine: 40 g, 2-3 ms
  • Non-operating:
    1/2-sine: 2-3 ms (~100 g), 160 cm/s
    square: 20 g, 422 cm/s
Vibration
  • Operating random: 0.5 g (RMS), 5-300 Hz
  • Non-operating random: 2.0 g (RMS), 10-500 Hz
Cooling
Above 1524 m (5,000 ft) altitude, maximum operating temperature is derated by 1°C (1.8°F) per 305 m (1,000 ft) elevation increase.
