HP Compaq LA1905wg, LA2205wg, LA22f, and LA2405wg LCD Monitors - Product Features
HP LCD Monitors
The LCD (liquid crystal display) monitors have an active matrix, thin-film transistor (TFT) panel. The monitor models and features include:
  • LA1905wg model, 48.1 cm (19-inch) diagonal viewable area display with 1440 × 900 resolution, plus full-screen support for lower resolutions; includes custom scaling for maximum image size while preserving original aspect ratio
  • LA2205wg model, 55.88 cm (22-inch) diagonal viewable area display with 1680 x 1050 resolution, plus full-screen support for lower resolutions; includes custom scaling for maximum image size while preserving original aspect ratio
  • LA22f model, 55.88 cm (22-inch) diagonal viewable area display with 1680 x 1050 resolution, plus full-screen support for lower resolutions; includes custom scaling for maximum image size while preserving original aspect ratio
  • LA2405wg model, 60.96 cm (24-inch) diagonal viewable area display with 1920 x 1200 resolution, plus full-screen support for lower resolutions; includes custom scaling for maximum image size while preserving original aspect ratio
  • Wide viewing angle to allow viewing from a sitting or standing position, or moving side-to-side
  • Tilt capability
  • Pivot capability to rotate display to portrait mode
  • Swivel and height adjustment capabilities
  • Removable stand for flexible monitor panel mounting solutions
  • Video signal input to support VGA analog with VGA signal cable provided
  • Video signal input to support DVI digital with DVI-D signal cable provided
  • Video signal input to support DisplayPort digital (DisplayPort cable not provided)
  • USB 2.0 hub with one upstream port (connects to the computer) and two downstream ports (connects to USB devices)
  • USB cable provided to connect the monitor's USB hub to the USB connector on the computer
  • Supports an optional HP speaker bar
  • Plug and play capability if supported by the system
  • Privacy filter slots to insert filters (purchased separately) to block side screen viewing
  • Security slot provision on rear of monitor for optional cable lock
  • Cable management feature for placement of cables and cords
  • On-Screen Display (OSD) adjustments in several languages for easy setup and screen optimization
  • HP Display Assistant for adjusting monitor settings
  • Pivot Pro software for viewing information on the screen in portrait mode
  • Theft deterrence software
  • HDCP copy protection on DVI and DisplayPort inputs
  • Software and documentation CD that includes monitor drivers and product documentation
  • Energy saver feature to meet requirements for reduced power consumption
  • Energy Star qualified
  • Intelligent Management AssetControl
  • Compliant with the following regulated specifications:
    • European Union CE Directives
    • Swedish TCO Requirements
