HP Compaq nx7000 Notebook PC - Removing and Replacing the Hard Disk Drive
This document is provided to assist in removing and replacing the hard disk drive for the HP Compaq nx7000 Notebook PC.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Tools required
Small, Phillips-head P0 screwdrivers
Parts required
The replacement part number will vary depending on the hard disk drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
30.0GB IDE hard disk drive - 4,200 RPM, 2.5 in form factor, 9.5 mm height
350081-001 (Original)
Yes
40.0GB ATA-100 EIDE hard drive - 4,200 RPM, 2.5 in form factor, 9.5 mm height
336989-001 (Modified)
Yes
60.0GB ATA-100 EIDE hard drive - 4,200 RPM, 2.5 in form factor, 9.5 mm height
336990-001 (Original)
Yes
60.0GB ATA-100 EIDE hard drive - 5,400 RPM, 2.5 in form factor, 9.5 mm height
336991-001 (Original)
Yes
80.0GB ATA-100 EIDE hard drive - 4,200 RPM, 2.5 in form factor, 9.5 mm height
336992-001 (Original)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the hard disk drive, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library) then select Hard disk drive from the menu on the upper left hand side of the screen.
Click here to view the hard disk drive removal video (right-click on the link to open in a new window/tab).
Hard disk drive removal
  2. Remove the two 7 mm P0 Phillips-head screws that secure the hard disk drive to the base enclosure.
  3. Lift the inside edge of the hard disk drive to unseat the hard disk drive connector from the system board.
  4. Pull the hard disk drive out of the bay.
  5. If present, remove the hard disk drive PIN extender.
    This procedure not shown in the video.
  6. Place the hard disk drive in a static dissipative bag.
Hard disk drive replacement
  1. Remove the hard disk drive from the static dissipative bag.
  2. If required, replace the hard disk drive PIN extender.
    This procedure not shown in video.
  3. Toe the outside edge of the hard disk drive into the drive bay.
  4. Press down on the hard disk drive to seat the hard disk drive connector to the system board.
  5. Replace the two 7 mm P0 Phillips-head screws.
