HP Compaq nc6220 Notebook PC - Removing and Replacing Keyboard
This document is provided to assist in removing and replacing the Keyboard for the HP Compaq nc6220 Notebook PC.
Minimum skill level
Tools required
Torx 8 (T8) screwdriver
Parts required
The replacement part number will vary depending on the Keyboard that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP.
Part Number
Requires Return
101/102-key compatible keyboard (Black) - Industry standard full-pitch layout, isolated inverted-T cursor control keys, integrated numeric keypad, instant-access hotkeys - 19.0mm x 19.0mm key pitch, 2.5mm stroke - Includes ribbon cable (United States)
378188-001
No
The part number will vary based on the country. Click here for a list of country specific spare part numbers.
Summary of instructions
To view a video demonstrating the procedure for removing the Keyboard, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Keyboard from the menu on the upper left hand side of the screen.
Click here to view the keyboard removal video (right-click on the link to open in a new window/tab).
Keyboard removal
  2. Remove the three T8-7 mm screws that secure the keyboard to the base enclosure.
  3. Turn the notebook right side up and open the display panel fully.
  4. Slide the four plastic locking tabs toward the bottom edge of the keyboard to unlock the keyboard from the LED switch cover.
  5. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and then place it upside down on the top cover.
  6. Using minimal force, lift the locking bar to unlock the keyboard ZIF connector on the system board.
    Use care to prevent damaging the ZIF connector and ribbon cable.
  7. Remove the keyboard ribbon cable from the ZIF connector.
  8. Using minimal force, lift the locking bar to unlock the pointing stick ZIF connector on the system board.
  9. Remove the pointing stick ribbon cable from the ZIF connector and remove the keyboard.
Keyboard replacement
  1. Place the keyboard right side up on the top cover.
  2. Insert the pointing stick ribbon cable into the pointing stick ZIF connector on the system board.
    Use care to prevent damaging the pointing stick ribbon cable.
  3. Push the locking bar down to lock the pointing stick ZIF connector on the system board.
  4. Insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
    Use care to prevent damaging the keyboard ribbon cable.
  5. Toe the tabs on the bottom edge of the keyboard into the top cover.
  6. Press the keyboard flat and slide the four plastic locking tabs toward the rear of the notebook to lock the keyboard to the LED switch cover.
  7. Close the display panel and turn the notebook upside down.
  8. Replace the three T8-7 mm screws that secure the keyboard to the base enclosure.
