HP Compaq nc6220 Notebook PC - Removing and Replacing Optical drive
This document is provided to assist in removing and replacing the Optical drive for the HP Compaq nc6220 Notebook PC.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Tools required
Small, Phillips-head (P0) screwdrivers
Parts required
The replacement part number will vary depending on the Optical drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
DVD-ROM drive (Multibay II) - 8X speed
373314-001 (Original)
Yes
DVD±RW combination drive (Multibay II) - 2.4X DVD+R write, 2.4X DVD+RW rewrite, 2X DVD-R write, 2X DVD-RW rewrite, 24X CD-R write, 10X CD-RW rewrite, 24X CD-ROM read, 8X DVD read
403711-001 (Original)
Yes
DVD-ROM/CD-RW combination drive (Multibay II) - 24X CD-R write, 24X CD-RW rewrite, 24X CD-ROM read, 8X DVD read
403710-001 (Original)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the Optical drive, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Optical drive from the menu on the upper left hand side of the screen.
Click here to view the optical drive removal video (right-click on the link to open in a new window/tab).
Optical drive removal
  2. Remove the 5 mm P0 Phillips-head screw that secures the optical drive to the base enclosure.
  3. Press and release the eject icon on the end of the optical drive front bezel to partially eject the optical drive.
  4. Grasp the sides and pull the optical drive out and remove.
Optical drive replacement
  1. Insert the optical drive into the base enclosure until the connector is seated.
  2. Replace the 5 mm P0 Phillips-head screw that secures the optical drive to the base enclosure.
