HP Compaq nc4200 Notebook PC - Removing and Replacing the Keyboard Cover
This document is provided to assist in removing and replacing the keyboard cover for the HP Compaq nc4200 Notebook PC.
Tools required
Torx 8 (T8) screwdriver.
Parts required
The replacement part number will vary depending on the keyboard cover that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP.
Part Number
Requires Return
Keyboard cover - Protective cover above the keyboard
383519-001 (Original)
No
Summary of instructions
To view a video demonstrating the procedure for removing the keyboard cover, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Keyboard cover from the menu on the upper left hand side of the screen.
Click here to view the keyboard cover removal video (right-click on the link to open in a new window/tab).
Keyboard cover removal
  2. Remove the two T8-18 mm screws that secure the keyboard cover to the base enclosure.
  3. Turn the notebook right side up and open the display panel fully.
  4. Use a flat-bladed tool to lift the keyboard cover hinge covers off of the display panel hinges.
  5. Swing the rear of the keyboard cover forward to separate it from the display panel and remove the keyboard cover.
Keyboard cover replacement
  1. Place the keyboard cover into position on the top cover.
  2. Press along the entire length of the keyboard cover to snap it into place.
  3. Close the display panel and turn the notebook upside down.
  4. Replace the two T8-18 mm screws that secure the keyboard cover to the base enclosure.
