HP Compaq nc6220 Notebook PC - Removing and Replacing Expansion memory board
This document is provided to assist in removing and replacing the expansion memory board for the HP Compaq nc6220 Notebook PC.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Tools required
Phillips-head (P0) screwdriver
Parts required
The replacement part number will vary depending on the expansion memory board that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
256MB, 533MHz, 240-pin, PC4200, DDR2 SDRAM SO-DIMM
373119-001 (Original)
Yes
512MB, 533MHz, 240-pin, PC4200, DDR2 SDRAM SO-DIMM
373120-001
Yes
1.0GB, 533MHz, 240-pin, PC4200, DDR2 SDRAM SO-DIMM
373121-001
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the expansion memory board, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Expansion memory board from the menu on the upper left hand side of the screen.
Click here to view the removal video (right-click on the link to open in a new window/tab).
Expansion memory board removal
  2. Loosen the captive P0 Phillips-head screw that secures the expansion memory cover to the bottom of the notebook.
  3. Use your finger or a flat-bladed tool to lift the edge of the expansion memory cover and remove it.
  4. Push both arms outward simultaneously to release the expansion memory board to the spring tension position.
    When handling a memory board, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
  5. Grasp the expansion memory board by the edges and pull gently to remove it.
  6. Place the expansion memory board in a static dissipative bag.
Expansion memory board replacement
  1. Remove the expansion memory board from the static dissipative bag.
  2. Locate the alignment slot and align it to the empty board receptacle.
  3. Grasp the expansion memory board by the edges and push gently to replace it.
  4. Press the expansion memory board down to latch the arms.
  5. Toe the expansion memory cover into the enclosure.
  6. Tighten the captive P0 Phillips-head screw.
Expansion memory board installation
  1. Loosen the captive P0 Phillips-head screw that secures the expansion memory cover to the bottom of the notebook.
  2. Use your finger or a flat-bladed tool to lift the edge of the expansion memory cover and remove it.
  3. Remove the expansion memory board from the static dissipative bag.
  4. Locate the alignment slot and align it to the empty board receptacle.
  5. Grasp the expansion memory board by the edge and push gently to install it.
  6. Press the expansion memory board down to latch the arms.
  7. Toe the expansion memory cover into the enclosure
  8. Tighten the captive P0 Phillips-head screw.
