HP Designjet 110plus Printer Series - Installing ADI Driver for AutoCAD Release 14
Step by step instructions on how to install the ADI driver for AutoCAD release 14 on the computer.
HP Designjet 110plus printer is not listed as the default printer under AutoCAD R14. ADI driver is required to be installed on the computer so that HP Designjet 110plus can be made available for installation under AutoCAD Release 14.
Details
Ensure that the CD-Drivers and documentation for Designjet 110plus contains the ADI driver for AutoCAD R14.
If CD is not available, go to the HP Software and Drivers page to download the driver.
Please follow the steps listed below to install the ADI driver for AutoCAD R14 on the computer using Driver CD for HP Designjet 110plus.
  1. Insert the CD into the CD drive. Select the language as English when prompted and click OK.
  2. Accept the terms and conditions and click Next.
  3. Under Printer connection, select Connected directly to this computer.
  4. Select the connector type as Parallel cable/USB.
  5. Select the model from the list:
  6. Under Installation type, select Custom Installation.
  7. Select AutoCAD 14 ADI driver from the list and click Next.
  8. Specify the printer name as HP Designjet 110plus for AutoCAD and click Next to install the ADI driver.
Once the ADI driver is installed successfully, AutoCAD Release 14 will display HP Designjet 110plus as supported model in the list.
The HP Designjet 110plus can be installed under AutoCAD R14.
