HP Pro All-in-One ms218/219 Business PC - Specifications
System unit
Feature
Dimensions (HxWxD)
18.47 x 2.17 x 13.03 inch (469.14 x 55.12 x 330.96 mm)
14.33 lb (6.5 kg)
Stand-Alone Power Requirements
Electrical Ratings: 100V to 240V
Average Operating Power: TBD
Max Operating Power: 120 Watts
Temperature
Operating: 50° to 104° F (10 to 40° C)
Non-operating: -20° to 140° F (-30° to 60° C)
Relative Humidity
Operating: 20 to 85%
Altitude (unpressurized)
Operating: 0 to 10,000 ft (3,048 m)
Non-operating: 0 to 30,000 ft (9,144 m)
Industry Standard Certifications
UL, CSA, FCC Compliance, ENERGY STAR, EPEAT TBD
Motherboard specifications
Feature
Motherboard description
  • Manufacturer: Quanta
  • HP/Compaq name: Capirona
CPU/Processor
  • Socket: AM2
  • Supports the following processors:
    • AMD Athlon X2 3xxxe (B)
    • AMD Athlon X2 6xxxe (B)
AMD m780G
BIOS features
  • Keyboard combination used to enter BIOS: F10
  • System BIOS core brand: Phoenix
Form factor
7.87x9.53 inch (20x24.2 cm)
Memory 1
  • Two DDR2 SO-DIMMs (200-pin) sockets
  • Supported DIMM types:
    • PC2-6400 MB/sec
  • Non-ECC memory only, unbuffered
  • Supports up to 4GB on 64-bit PCs
  • Supports up to 4GB on 32-bit PCs
  • Maximum memory only if using 2GB DDR2 SO-DIMM modules
Expansion Slots
One PCI Express x1 mini card socket
Video graphics
  • Integrated graphics using AMD HD3200
  • One Mobile PCI Express Module (MXM) socket (socket included only with selected Capirona models)
    • MXM version: 3.0, type A
    • Less than 30W
    • Used for MXM graphics card included with selected models
Serial ATA2
Two SATA connectors:
  • Supports one SATA-150 or SATA-300 disk drive on each SATA connector
  • Speed up to 1.5Gb/sec or 3.0Gb/sec, complying with SATA 1.0 and SATA 2.0 specifications
Onboard audio
  • Audio codec: Realtek ALC269
  • Supports two audio channels through an analog connection
Onboard LAN 3
One Realtek RTL8103EL 10/100 Mb/s
Onboard USB 4
  • USB 2.0
  • Six available ports total
    • Four connectors on back panel
    • Two headers on motherboard support two additional ports
Sidel I/0 panel ports
Listed in physical order from left to right:
  • One Headphone out
  • One Microphone in
  • Two USB 2.0 ports
  • One slot for integrated card reader
Internal connectors
  • PC volume control
  • PC fan connector
  • Audio signals to LCD display
  • SATA Power connector
  • ODD + LED connector
  • Microphone jack
  • Inverter connector
  • Two USB connectors
  • Hotkey connector
  • Front headphone jack
  • Two CPU fan connectors
  • Card reader connector
  • USB bluetooth connector
  • ATX power connector
  • HDD power connector
  • LEDs in the front panel
1: Actual available memory may be less
2: The faster rate of 3.0 Gb/sec requires that both the hard drive and the motherboard support it. If one or the other does not support 3.0 Gb/sec, the PC negotiates down to the slower 1.5 Gb/sec.
3: Gigabit Ethernet is backwards compatible with 10/100 Mb/s network hardware.
4: Additional ports may show in Device Manager. These ports are dedicated to PC components.
