    Fix HP Printer issue on macOS
HP ZR24w 24-inch Widescreen LCD Monitor Specifications
Product description
HP introduces a new Performance Series monitor with the extreme visual Performance with 8-way comfort adjustments and power-saving features.
Product features
Feature
Model
VM633A4
Type
Wide-Aspect Active Matrix TFT
Viewable Image Area
61 cm (24 in) widescreen; diagonally measured
Screen Opening (W x H)
52.04 x 32.6 cm (20.49 x 12.83 in)
Panel Type
S-IPS (H2-IPS technology for improved energy efficiency)
Native Resolution
1920 x 1200
Aspect Ratio
16:10
Input signal
DisplayPort , DVI-D, and VGA connectors; HDCP support on DisplayPort and DVI
Viewing Angle (typical)
Up to 178° horizontal/178° vertical (10:1 minimum contrast ratio)
Brightness (typical)*
400 nits (cd/m2)
Contrast Ratio (typical)*
1000:1, 3000:1 Dynamic Contrast Ratio (DCR)
Response Time (typical)*
5 ms (gray to gray); 12 ms (On/Off)
Pixel Pitch
0.270 mm
Backlight Lamp Life (to half brightness)
50K hours
Color Support
16.7 million colors
Ergonomic features
  • Tilt range: -5° to +30° vertical
  • Swivel range: -45° to +45°
  • Height: Up to 10.0 cm (3.94 in)
  • Pivot: Yes
Color Gamut Area vs. NTSC
83% (CIE 1976), 72% (CIE 1931)
Color Gamut Coverage of sRGB
97% (CIE 1931)
Panel specifications
Type
Wide-Aspect Active Matrix TFT (thin film transistor)
Viewable Image Area
Panel Type
Resolution
1920 x 1200
Aspect Ratio
16:10
Brightness (typical)1
400 nits (cd/m2)
Contrast Ratio (typical)1
1000:1, 3000:1 DCR (Dynamic Contrast Ratio)
Response Time
Pixel Pitch
0.270 mm
50 k hours
Color Support
16.7 million colors
97% (CIE 1931)
1: All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
On Screen Display (OSD) Controls specifications
Specification
Buttons or Switches
Menu, OSD down , OSD up (Source), OK (Auto), Power
Languages
English, French, German, Spanish, Italian, Dutch, Japanese, S. Chinese, T. Chinese, Brazilian Portuguese
User Controls
Brightness, contrast, positioning, color temperature (5000k-Warm, 6500k-sRGB, 9300k-Cool, custom), serial number, display, clock, clock phase, monitor management, factory reset
Signal interface/performance specifications
Specification
Horizontal Frequency
24 to 80 kHz
Vertical Frequency
59 to 61 Hz
Native Resolution
1920 x 1200 @ 60 Hz (WUXGA), 2.3 million pixels
Preset VESA Graphic Modes (non-interlaced)
  • 1920 x 1080 @ 60 Hz
  • 1680 x 1050 @ 60 Hz
  • 1600 x 1200 @ 60 Hz
  • 1440 x 900 @ 60 Hz
  • 1280 x 1024 @ 60 Hz
  • 1280 x 960 @ 60 Hz
  • 1024 x 768 @ 60 Hz
  • 800 x 600 @ 60 Hz
  • 640 x 480 @ 60 Hz
Text Mode
720 x 400 @ 70 Hz
Maximum Pixel Clock
200 MHz (VGA)
Speed
170 MHz (DVI, DisplayPort)
User Programmable Modes
Yes, 20
Anti-Glare
Yes
Anti-Static
Yes
Default Color Temperature
6500 K
Video/other inputs specifications
Specification
Plug and Play
Yes
Self Powered USB 2.0 Hub
One upstream, four downstream ports (cable included)
USB Cable Length
1.8 m (5.9 ft)
Input Connectors
1 DisplayPort connector, 1 DVI-D connector, 1 VGA connector, HDCP support on DisplayPort and DVI
Input Impedance
75 ohms ± 10%
Sync Input
Separate sync (HSYNC/VSYNC); composite sync, Sync on Green
DVI-D Video Cable Length
1.8 m (5.9 ft)
DisplayPort Video Cable Length
1.8 m (5.9 ft)
Power specification
Specification
Input Power
Auto-Sensing, 90 to 265 V ac
Frequency
47 - 63 Hz
Typical Power Consumption
< 85 watts (without speaker/with 50% USB)
Maximum
< 95 W
Power Saving
  • < 1 W sleep mode
  • < 1 W off
Power Cable Length
1.9 m (6.2 ft)
Ergonomic Features specifications
Specification
8-Way Comfort Adjust
Easily adjust the display in height, tilt, swivel and pivot for maximum comfort. Eight degrees of adjustment freedom including height up/down, tilt forward/back, swivel left/right and pivot portrait/landscape.
HP Quick Release
Ultra convenient set up. Easily mount and detach the display head from the stand.
Cable Management
Enhanced cable management for easy concealment of power, video and USB cables. Effortless routing of cables through the base of the column with removable cover plate.
Detachable Stand
Stand ships detached and easily attaches with the HP Quick Release.
Tilt Range
Swivel Range
45° L / 45° R
Height Adjustable
Height Adjustable
Pivot Rotation
Yes
Physical specifications
Specification
Dimensions (H x W x D)
Packaged
  • 43.2 x 65 x 33.3 cm (17 x 25.6 x 13.11 in)
Unpackaged w/o stand
  • 36.2 x 55.6 x 8.65 cm (14.25 x 21.89 x 3.41 in)
Unpacked w/stand
  • 42.5 x 55.6 x 23.5 cm (16.79 x 21.89 x 9.25 in)
Packaged
  • 0.49 kg (1.1 lb)
Unpackaged
  • 0.37 kg (0.82 lb)
Environmental specifications
Specification
Operating Temperature
5° to 35°C (41° to 95°F)
Non-operating Temperature
-20° to 60°C (-29° to 140°F)
Operating Humidity
20% to 80% non-condensing
Non-operating Humidity
5% to 95%, 38.7°C max wet-bulb
Operating Altitude
+3,658 m (12,000 ft)
Non-operating Altitude
+12,192 m (40,000 ft)
Environmental Data specifications
Specification
Energy Certifications and Declarations
This product has received or is in the process of being certified to the following approvals and may be labeled with one or more of these marks:
  • IT ECO declaration
Energy Consumption (in accordance with US Energy Star test method)
115 V ac, 60 Hz
  • Normal Operation - 88.3 W
  • Sleep - 0.70 W
  • Off - 0.57 W
230 V ac, 50 Hz
  • Normal Operation - 88.53 W
  • Sleep - 0.85 W
  • Off - 0.74 W
100 V ac, 60 Hz
  • Normal Operation - 89.27 W
  • Sleep - 0.67 W
  • Off - 0.56 W
Heat Dissipation1
115 V ac, 60 Hz
  • Normal Operation - 302 BTU/hr
  • Sleep - 2 BTU/hr
  • Off - 2 BTU/hr
230 V ac, 50 Hz
  • Normal Operation - 303 BTU/hr
  • Sleep - 3 BTU/hr
  • Off - 3 BTU/hr
100 V ac, 60 Hz
  • Normal Operation - 305 BTU/hr
  • Sleep - 2 BTU/hr
  • Off - 2 BTU/hr
Additional Information
  • This product is in compliance with the Restrictions of Hazardous Substances (RoHS) directive - 2002/95/EC.
  • This HP product is designed to comply with the Waste Electrical and Electronic Equipment (WEEE) Directive – 2002/96/EC.
  • This product is in compliance with California Proposition 65 (State of California; Safe Drinking Water and Toxic Enforcement Act of 1986).
  • Plastics parts weighing over 25 grams used in the product are marked per ISO 11469 and ISO1043.
  • This product contains 0 % post-consumer recycled plastic (by wt.)
  • This product is 65 % recycle-able when properly disposed of at end of life.
Packaging Materials
External:
  • Paper/Cardboard - 20 g
Internal:
  • EPS (Expanded Polystyrene) - 503 g
  • EPS (Expanded Polystyrene) - 90 g
RoHS Compliance
Hewlett-Packard is committed to compliance with all applicable environmental laws and regulations, including the European Union Restriction of Hazardous Substances (RoHS) Directive. HP’s goal is to exceed compliance obligations by meeting the requirements of the RoHS Directive on a worldwide basis. By July 1, 2006, RoHS substances will be virtually eliminated (virtually = to levels below legal limits) for all HP electronic products subject to the RoHS Directive, except where it is widely recognized that there is no technically feasible alternative (as indicated by an exemption under the EU RoHS Directive).
1: Heat dissipation is calculated based on the measured watts, assuming the service level is attained for one hour.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
