Specification
Dimensions (H x W x D)
Unpacked w/stand
Packaged
Unpacked
6.0 kg (13.23 lb)
Tilt Range
–5° to + 25° vertical
Swivel
Yes
Base
Detachable
- ${title}
- ${title}
- ${title}
- ${title}
HP Compaq L2301w 23-inch Widescreen LCD Monitor - Specifications
Physical specifications
Panel specifications
Specification
Type
23-inch Wide-Aspect Active Matrix TFT (thin film transistor)
Viewable Image Area
58.42 cm (23 in) widescreen; diagonally measured
Panel Type
TN
Aspect Ratio
16:9
Viewing Angle (typical)
Up to 160° horizontal/160° vertical (10:1 minimum contrast ratio)
Brightness (typical)*
300 nits (typical)
Contrast Ratio (typical)*
1000:1 (DCR 3000:1)
Response Time (typical)*
5 ms (On/Off)
Pixel Pitch
0.265 mm
Backlight Lamp Life
(to half brightness)
50K hours
Color Gamut
72% color gamut (NTSC,TYP)
note: |
On Screen Display (OSD) controls specifications
Specification
Buttons or Switches
OSD Menu, OSD "-" Navigate, OSD "+" Navigate (Source Mode Hot Key);
OSD Select (Auto Adjust Hot Key), Power
Languages
English, French, German, Italian, Dutch, Spanish, Brazilian Portuguese,
Japanese, S. Chinese
User Controls
Switch Video Input, Brightness, Contrast, Image Control, Color, Language,
Management, Image Control, Information, Factory Reset, Exit
Signal interface/ performance specifications
Specification
Horizontal Frequency
24 to 83 kHz
Vertical Frequency
50 to 76 Hz
Native Resolution
1920 x 1080 @ 60 Hz
Preset VESA Graphic
Modes (non-interlaced)
Anti-Glare
Yes
Anti-Static
Yes
Default Color
Temperature
6500 K
Video/ other inputs specifications
Specification
Plug and Play
Yes
Input Connectors
VGA, DVI-D
Input Impedance
75 ohms ± 10%
Sync Input
TTL separate synch
Video Cable
One 15-pin D-sub (VGA) and one DVI
Video Cable Lengths
VGA 1.8 m (5.9 ft) and DVI 1.8m (5.9 ft)
Audio specifications
Specification
Speakers
Integrated, bottom facing
Audio Cable
Power specifications
Specification
Input Power
Auto-Sensing, (100 to 240 VAC)+/-10%
Frequency
50 to 60 Hz
Typical Power
Consumption
< 43 watts
Maximum
< 51 watts
Power Saving
< 2 watts standby
Power Cable Length
1.9 m (6.2 ft)
Environmental specifications
Specification
Temperature
Operating
Non-operating
Humidity
Operating
Non-operating
Altitude
Operating
Non-operating
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
