Compaq Mini 102 - Overview
Product description
The affordable, small and stylish Compaq Mini 102 packs a rich mobile internet experience, and empowers mobile professionals and students to get more accomplished.
Product features
Feature
Mobile Intel 945GSE Express Chipset
Processors
Intel Atom N270 Processor (1.6-GHz, 512KB L2 cache, 533 MHz FSB)
Intel's numbering is not a measurement of higher performance. Processor speed denotes maximum performance mode; processor will run at lower speeds in battery optimization mode.
Memory
Standard: 1GB DDR2 SDRAM SODIMM1 one SODIMM slot.
Maximum: Supports up to 1GB maximum.
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility.
Graphics
Mobile Intel Graphics Media Accelerator 950
Internal:
  • 10.1 in diagonal LED-backlit WSVGA display with 1024 x 600 resolution
External:
  • Up to 32-bit per pixel color depth
  • VGA port supports resolutions up to 1600 x 1200 at 75 Hz, and WUXGA at 60 Hz
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Keyboard
Keyboard is 92% of full size, 101/102-key compatible with isolated inverted-T cursor control keys, both left and right control and alt keys, 12 function keys, and hotkey combinations for audio volume, power conservation, brightness, and other features. US and international key layouts are available.
Pointing device
Touchpad with scroll zone and two soft-touch buttons
Storage
Internal Storage Device :
  • 160GB 5400 rpm SATA Hard Drive
  • 16GB Solid State Module
Up to 15GB is reserved for the system recovery software.
Power Supply
External 30 W AC adapter, 1 mt (3.3 ft) power cord included
Battery
Primary battery:
  • 3-cell (28.8 WHr) Li-Ion
  • 6-cell (55 WHr) high capacity Li-Ion
1: All memory modules operate at the maximum system supported speed of 533 MHz.
Software overview
Feature
Operating System
  • Windows 7 Starter 32
  • Genuine Windows XP Home
