HP Photosmart e-All-in-One Printer Series (D110) - Alignment Page Does Not Print
Issue
After you install new cartridges, the product does not print an alignment page as expected.
Try the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting.
Solution one: Make sure the front access door is not open
Check the front access door. If the door is open, close it.
Figure : Close the front access door
Illustration of closing the front access door
  • If the alignment page prints automatically, continue to "Solution five, Step two" in this document to complete the alignment process.
  • If the alignment page does not print, continue to the next solution.
  1. With the product turned on, open the front access door. The carriage moves to the center of the product.
    Figure : Open the front access door
    Illustration of opening the front access door
  2. Inspect the area around the carriage for any obstructions, including packing material. Remove any obstructions.
  3. Close the front access door.
  1. Make sure the product is on.
  2. Open the front access door.
  3. Wait for the carriage to move to the center of the product.
  4. Press down on one of the cartridges to release it, and then pull it out from its slot.
    Figure : Example of removing the tri-color cartridge
    Illustration of removing the tri-color cartridge.
  5. Hold the cartridge by its sides.
    Figure : Hold the cartridge by its sides
    Illustration of holding the cartridge
  6. Reinsert the cartridge into its designated slot. The black parallelogram icon () designates the slot for the black cartridge, and the magenta half circle icon () designates the slot for the color cartridge.
    Figure : Example of inserting the tri-color cartridge
    Illustration of inserting the cartridge
  7. Press the cartridge in to snap it into place.
  8. Repeat these steps to remove and then reinsert the other cartridge.
  9. Close the front access door.
Solution four: Reset the All-in-One
Follow these steps to perform a hard reset.
  1. Without turning off the product, disconnect the power cord from the rear of the product.
  2. Wait 30 seconds.
  3. Reconnect the power cord to the rear of the product.
Solution five: Realign the cartridges
Follow these steps to print an alignment page and realign the cartridges.
Step one: Print an alignment page
  1. Load plain white paper in the input tray.
  2. Open HP Solution Center:
    • Windows XP: Click Start, click All Programs, click HP, and then click HP Solution Center.
    • Windows Vista or Windows 7: Click the Windows icon (), click All Programs, click HP, and then click HP Solution Center.
    HP Solution Center opens in a new window.
  3. In HP Solution Center, click Settings ().
  4. In the Print Settings area, click Printer Toolbox. The printer Toolbox opens in a new window.
  5. Click Align the Print Cartridges ().
  6. Click Print Page. The product prints an alignment page.
    Figure : Product prints an alignment page
    Illustration of the product printing an alignment page
Step two: Scan the alignment sheet
  1. Lift the product lid.
  2. Place the alignment page on with the printed-side down on the right-front corner of the scanner glass. See the engraved guide next to the scanner glass for help loading the alignment page.
    Figure : Load the alignment page
    Illustration of loading the alignment page
  3. Lower the product lid.
  4. Close the lid, and then press OK to complete the alignment.
  5. Wait while the product scans the alignment sheet and completes the alignment process.
  6. When the cartridge alignment is complete, recycle or discard the alignment page.
Country: Flag Thailand
