    Looking for Site Help?
HP ZR22w 21.5-inch Widescreen LCD Monitor - Specifications
Physical specifications
Feature
Dimensions (H x W x D)
Unpacked with stand (single)
  • 36.7 to 45.7 x 50.7 x 23 cm (14.4 to 18.0 x 20.09 x 9.1 in)
Unpacked without stand (head only)
  • 30.3 x 50.7 x 6.4 cm (11.9 x 20.0 x 2.5 in)
Packaged (single)
  • 39.4 x 57.1 x 31.6 cm (15.5 x 22.5 x 12.4 in)
  • 7.24 kg (15.9 lb)
  • 4.26 kg (9.4 lb)
Packaged (single)
  • 9.66 kg (21.3 lb)
Panel specifications
Feature
Type
Wide-Aspect Active Matrix TFT (thin film transistor)
Viewable Image Area
54.61 cm (21.5 in) widescreen; diagonally measured
Screen Opening (W x H)
47.5 x 29.8 cm (18.87 x 11.7 in)
Panel Type
S-IPS (UH-IPS technology for improved energy efficiency)
Resolution
1920 x 1080, Full HD
Aspect Ratio
16:9
Viewing Angle (typical)
Up to 178° horizontal/178° vertical (10:1 minimum contrast ratio)
Brightness (typical)
250 nits (cd/m2)
Contrast Ratio (typical)
1000:1, 3000:1 DCR (Dynamic Contrast Ratio)
Response Time (typical)
8 ms (gray to gray), 16 ms (on/off)
Pixel Pitch
0.2475 mm
Backlight Lamp Life (to half brightness)
5.0 K hours
Color Support
16.7 million colors
Color Gamut Size vs. NTSC
82% (CIE 1976)
Coverage of sRGB
96% (CIE 1931), 90% (CIE 1976)
All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
On Screen Display (OSD) controls specifications
Feature
Buttons or Switches
OSD menu select, OSD down, OSD UP/Source, OK/auto, power
Languages
English, French, German, Spanish, Italian, Dutch, Japanese, S. Chinese, T. Chinese, and Brazilian Portuguese
User Controls
Brightness, contrast, OSD control, color temperature (5000 K, 6500 K (sRGB), 9300 K, custom), individual color control, information, video input control, clock, clock phase, monitor management, factory reset
Signal interface/performance specifications
Feature
Horizontal Frequency
24 to 94 KHz (DVI input for modes with pixel clock less than 165 MHz)
Vertical Frequency
50 to 76 Hz (DVI input for modes with pixel clock less than 165 MHz)
Native Resolution
1920 x 1080 @ 60 Hz, 2.1 Million pixels
Preset VESA Graphic
1920 x 1080 @ 60 Hz
Modes (non-interlaced)
  • 1680 x 1050 @ 60 Hz
  • 1600 x 1200 @ 60 Hz
  • 1440 x 900 @ 60 Hz
  • 1280 x 1024 @ 60 Hz
  • 1280 x 960 @ 60 Hz
  • 1280 x 720 @ 60 Hz
  • 1024 x 768 @ 60 Hz
  • 800 x 600 @ 60 Hz
  • 640 x 480 @ 60 Hz
Text Mode
720 x 400 @ 70 Hz
Maximum Pixel Clock Speed
200 MHz (analog input); 165 MHz (DVI input and DP input)
User Programmable Modes
Yes, 20
Anti-Glare
Yes
Anti-Static
Yes
Default Color Temperature
6500 K
Video/other inputs specifications
Feature
Plug and Play
Yes
Self Powered USB 2.0 Hub
One upstream, four downstream ports (cable included)
USB Cable Length
1.8 m (5.9 ft)
Input Connectors
1 DisplayPort connector, 1 DVI-D connector, 1 VGA connector, HDCP support on DisplayPort and DVI.
Input Impedance
75 ohms ± 10%
Sync Input
Separate sync (HSYNC/VSYNC)
DVI-D Video Cable Length
1.8 m (5.9 ft)
DisplayPort Video Cable Length
1.8 m (5.9 ft)
Power specifications
Feature
Input Power
Auto-Sensing, 100 to 240 V ac, 50 +/-3 Hz to 60 +/-3 Hz)
Frequency
47.5 to 63 Hz
Typical Power Consumption
33.5 watts (120 V ac, USB ports 25% of maximum load)
Maximum
< 44 watts
Power Saving
< 1 watt sleep mode, < 1 watt off
Power Cable Length
1.9 m (6.2 ft)
Ergonomic features
Feature
8-Way Comfort Adjust
Easily adjust the display in height, tilt, swivel and pivot for maximum comfort. Eight degrees of adjustment freedom including height up/down, tilt forward/back, swivel left/right and pivot portrait/landscape.
HP Quick Release
Ultra convenient set up. Easily mount and detach the display head from the stand.
Cable Management
Enhanced cable management for easy concealment of power, video and USB cables. Effortless routing of cables through the base of the column with removable cover plate.
Detachable Stand
Stand ships detached and easily attaches with the HP Quick Release.
Tilt Range
-5° to + 30° vertical
Swivel Range
-45° to + 45°
Height Adjustable
Yes, range 9.0 cm (3.5 in)
Pivot Rotation
Yes
Environmental specifications
Feature
Operating Temperature
5° to 35° C (41° to 95° F)
Non-operating Temperature
-20° to 60° C (-4° to 140° F)
Operating Humidity
20% to 80% non-condensing
Non-operating Humidity
5% to 95%, 38.7° C max wet-bulb
Operating Altitude
+5,000 m (16,400 ft)
Non-operating Altitude
+12,192 m (40,000 ft)
Environmental data specifications
Feature
Energy Certifications and Declarations
This product has received or is in the process of being certified to the following approvals and may be labeled with one or more of these marks:
  • ENERGY STAR 5
  • EPEAT - Gold
  • IT ECO declaration
  • Korea Eco-label
  • TCO 5
  • CEL Level 2
Energy Saving Features
  • 85% power supply efficiency
  • Power Saving 2-lamp CCFL backlight
  • HP LiteSaver Software to enable user to schedule monitor power down on programmable schedule
  • HP WattSaver technology that reduces standby power to less than 1 watt
Earth Friendly Materials
  • Recycled resin in cabinet/stand, 28% minimum
  • Recyclable product materials, 10.8% minimum
  • Recycled packaging materials, 80% minimum
  • Recyclable packaging materials, 95% minimum
  • Arsenic-free LCD panel
Country: Flag Thailand
