HP Compaq LA22f 22-inch Widescreen LCD Monitor - Overview
Product description
LA22f 22-inch Widescreen LCD monitor offers advanced features and functionality, a superior ergonomic design, and the latest technologies for use in a variety of small-to-medium businesses as well as corporate environments.
Product features
Feature
Model
VU893AA
Type
22-inch Wide-Aspect Active Matrix TFT (thin film transistor)
Viewable Area (diagonal)
55.9 cm (22 in) widescreen; diagonally measured
Screen Opening (W x H)
47.8 x 30.0 cm (18.8 x 11.8 in)
Native Resolution
1680 x 1050 @ 60 Hz (WSXGA+), 1.76 Million pixels
Signal Input
VGA, DVI-D, and DisplayPort connectors; HDCP support
Viewing Angle
Up to 160° horizontal/160° vertical (10:1 minimum contrast ratio)
Brightness (typical)
250 nits (cd/m2)
Backlight Lamp Life (to half brightness)
50K hours
Contrast Ratio (typical)
1000:1
Pixel Pitch
0.282 mm
User Programmable Modes
20
Plug and Play
Yes
Language Selection
Yes
Anti-Glare
Yes
Anti-Static
Yes
Swivel Range
-170° to + 170°
Tilt Range
-5° to + 30° vertical
Height Adjustable
Yes, up to 12.0 cm (4.72 in)
Pivot Rotation
Yes
Base
Attachable, ships attached
