HP TeachNow Solution - Overview
Product description
HP TeachNow is a complete end-to-end classroom or lab solution. It is a server based application that delivers operating systems and applications on-demand to thin clients via OS Streaming technology. The server is used as a virtual disk drive, so clients do not require a hard disk or flash memory. All operating system and application processing is done by the client. Up to 40 clients per server are supported.
Product features
Feature
Server
HP ProLiant ml110 G6 server w/Windows 2008 x64 R2
Switch
HP ProCurve Switch 1810G-24
Hardware features
  • Intel Atom N280 processor, with Intel GL40 chipset
  • Up to 4GB flash memory provides ample storage for drivers and applications.(Up to 1 GB may not be available with 32-bit operating systems due to system resource requirements.)
  • 1 or 2GB DDR3/667MHz system memory (64 MB minimum reserved for graphics memory).
  • Available empty DDR3 SO-DIMM slot (and RAM upgrade options) for dual-channel system memory expansion.
    • Minimum of 1GB and a maximum of 8GB (2 X 4GB ) can be supported.
  • Built in dual monitor support (VGA and DisplayPort native).
  • Optional Expansion Module with PCI-E X4 or PCI slot for installing a wide range of devices (includes a parallel and second serial port).
  • Secure USB compartment is ideal for protecting USB wireless and USB Flash devices as well as for protecting USB keyboard and mouse connectors.
  • Additional SATA II connector for adding optional secondary solid state Flash drive (16GB available).
  • 8 USB 2.0 ports.
  • Legacy support includes parallel (via Expansion Module), serial, and PS/2 connections.
Protected by Hewlett-Packard Services, including a limited three-year mail-in warranty (certain restrictions and exclusions apply).
Software overview
Feature
Server OS compatibility/ support
  • Citrix XenApp 4.5
  • Citrix XenDesktop 2.x, Citrix XenDesktop 3, and Citrix XenDesktop 4
  • Citrix Presentation Server 4.0
  • Windows Server 2008 Terminal Services.
  • Windows 2000/2003 Server families, Windows 2000/2003 Server Terminal Services.
  • VMware View Manager 2.x and 3.1
Operating system/ Protocols/Components
Depends on model includes Windows 7 diskless COA w/ downgrade rights (to XP Pro).
