    Fix Windows 10 Update Issues
HP t5325 Thin Client - Specifications
Product description
The HP t5325 essential class Thin Client provides an optimized Windows, Citrix and VDI client virtualization experience with a breakthrough combination of performance, efficiency and affordability.
Product features
Feature
Processor
  • Marvell ARM 88F6281 1.2 GHz
  • XGI VOLARI-Z11-A2CB-HF with 64MB dedicated memory
Memory
  • 512MB DDR2 RAM + 64MB dedicated video RAM
Flash memory
  • 512MB
Graphics
  • XGI VOLARI with 64MB dedicated video RAM
Audio
Output:
  • Internal amplified speaker
  • 1/8-inch mini-jack
  • 24-bit stereo
  • 192-kHz sample rate
Input:
  • 1/8-inch microphone mini-jack
  • 20-bit stereo
  • 96-kHz sample rate
Networking
  • 10/100 Ethernet (RJ-45)
  • DHCP or Static IP support
  • Wake on LAN (WOL)
Input/output/peripheral Support
  • Keyboard: USB keyboard
  • Mouse: USB mouse
  • Printer: Local and/or network printers (RDP, ICA, LPD)
  • Video: DVI-I digital video output (DVI to VGA adapter included)
Electrical specifications
Feature
Operating voltage range
  • 100 to 240 V AC
Rated line frequency
  • 50 to 60 Hz
Power output (maximum)
  • 36 W
Rated output current (maximum)
  • 3 A
Output voltage
  • +12 V DC
Physical specifications
Feature
Dimensions (d x w x h)
  • 120 x 160 x 31.5 mm (4.72 x 6.3 x 1.24 in)
  • Ship weight: 2.12 kg (4.67 lb)
  • Stand-alone unit weight: 0.48 kg (1.06 lb)
Feature
  • HP ThinPro
Server OS compatibility
  • Citrix XenApp 4.5 and 5.0
  • Citrix XenDesktop 3 and 4
  • Citrix Presentation Server 4.0 and 4.5
  • Windows Server 2008/2008 R2 Remote Desktop Services
  • Windows 2000/2003 Terminal Server families
Environmental specifications
Features
Temperature range
Operating:
  • 10° to 35°C (50° to 95°F)
Non-operating:
  • -30° to +60°C (-22° to +140°F)
Humidity (non-condensing)
Operating:
  • 10% to 90%
Non-operating:
  • 5% to 95%
Regulatory compliance
Feature
Ergonomics
  • The product has been tested and found to comply with all applicable GS ergonomic requirements.
Product safety
  • International: IEC 60950-1, 12:2005, with CB certificate and all national deviations
    US and Canada: UL 60950-1 / CAN/CSA 22.2 No. 60950-1-03, 07:2006, Bi-National Standard for ITE Safety in the US and Canada and is published jointly by UL and CSA.
    Europe: EN 60950-1, 06:2003, Information Technology Equipment
RF interference
  • FCC Class B, CE Mark, VCCI
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
