Document ID: c01951676
Version: 1
HP EliteBook 2530p Notebook PC System BIOS Update F.10
Release date : 03-Dec-2009
Last updated : 08-Dec-2009
รายละเอียดการเปลี่ยนแปลง
  • A new option has been added that enables Computrace to be enabled or disabled. This option can only be set at the factory.
  • Fixes an issue where an unexpected 602 warning error is displayed when using a travel battery.
  • Fixes an issue where the computer is unable to boot from some attached USB devices.
  • Fixes an issue where fn+f4 does not work if num lock is enabled.
REASON FOR CHANGE
To implement changes under "Details of Change."
IMPACT OF CHANGE
None.
Components affected:
DATE OF CHANGE
Effective date : 18-Dec-2009
Hardware platforms affected : HP EliteBook 2530p Notebook PC
