HP 40gs Graphing Calculator - Manipulating Expressions in the EquationWriter
The EquationWriter
The HP 40gs contains an application known as the EquationWriter that is able to solve a wide range of problems. To access the EquationWriter, make sure the HP 40gs is in the home view by pressing the key. When in the home view, the display will look similar to the one shown below.
Figure : Displaying the home screen
Press to start the EquationWriter. The screen will now appear as shown below.
Figure : Displaying the EquationWriter screen
The EquationWriter is one of the most useful tools built into the HP 40gs calculator. With it, you can work through complicated calculations and see the equation take shape before your eyes. Since the EquationWriter displays the evolving calculation in a textbook format, it is possible to easily compare the display to an equation on paper and ensure proper entry. The arrow keys allow movement around the EquationWriter screen to make changes to different areas of the expression being entered.
The EquationWriter environment includes several tools for manipulating expressions entered. These tools are found in the menu. These tools include the ability to cut, copy, and paste portions of an expression to other areas within an expression as well as edit portions of an expression without affecting the remainder of the expression.
Some of these uses are illustrated by the example problems below.
Practice manipulating expressions in the EquationWriter
Example 1
Enter an expression and illustrate the use of the Cut, Copy and Paste tools.
Solution
Figure : Entering the expression
Now cut a portion of the expression from the denominator and paste it into the numerator.
Figure : Highlighting the second term of the denominator
Figure : Accessing the TOOL menu
Figure : Selecting the Cut option from the Tool's menu
Figure : Displaying the remaining terms
Figure : Highlighting the numerator
Figure : Selecting the Paste option from the Tool's menu
Figure : Inserting the value in the numerator
Figure : Highlighting the first portion of the denominator
Figure : Selecting Edit expression
Figure : Editing the denominator
Figure : Displaying the revised denominator
Figure : Entering the second term of the denominator
Answer
The point of this example is not so much to come to a numeric answer, but to show how the EquationWriter might work in practice. It is designed to be an interactive scratchpad, where you work through problems in any way you want. The editing tools provide a way to change your mind in the middle of a problem.
Country: Flag Thailand
