    Fix Windows 10 Update Issues
    Are you working from home?
HP Printers - Print with HP ePrint App (Android, Amazon Fire)
This document is for HP wireless printers and Android and Amazon Fire smartphones and tablets.
Print from your Android or Amazon Fire device with the HP ePrint app.
The HP ePrint app retired for Android, Amazon Fire, and Apple iOS devices. For more information, see How does the retirement of the HP ePrint app affect my device? in the Frequently asked questions (FAQs) section.
The HP ePrint app is a mobile application that lets you print to any supported HP printer that is on the same wireless network as your mobile device and to cloud-connected printers. HP ePrint is a cloud-based service that lets you email the document or photo you want to print directly to an HP web-enabled printer from anywhere with an active internet connection. Go to Printing with HP ePrint for more information.
Example of the HP ePrint app icon
Print with the HP ePrint app
Print documents, photos, email, and webpages from your mobile device or cloud services such as Google Drive and Dropbox.
To print a file that is not .jpg, .png, or .pdf, you must activate the HP ePrint app on your Android device. Follow the on-screen prompts to activate the app or go to How do I activate the HP ePrint app after installation? in the Frequently asked questions (FAQs) section.
Review the list of frequently asked questions about setting up and using the HP ePrint app.
