HP Compaq LA1951g 19-inch LCD Monitor.
Feature
Panel
Type
Active matrix, thin film transistor (TFT)
Viewable Image Area
19 in (48.25 cm)
Screen Opening
(W x H)
14.9 x 11.9 in (37.8 x 30.3 cm)
Viewing Angle (typical)
Up to 160° horizontal/160° vertical (10:1 contrast ratio)
Pixel Pitch
0.294 mm
Backlight Lamp Life
(to half brightness)
40K hours
On Screen Display
(OSD) Controls
Buttons or Switches
3-button OSD (menu, minus, plus); power on/off; second level OSD buttons
include dual-input switch, auto-adjus.t
Languages
English, Spanish, French, German, Dutch, Italian, Simplified Chinese,
Japanese.
User Controls
Size and positioning, contrast, brightness, clock, clock phase, selectable
color temperature, serial number, mode displayed, sleep timer, input
selection, factory reset, individual color contrast, full-screen resolution.
Signal Interface/
Performance
Horizontal Frequency
24 to 83 kHz
Vertical Frequency
50 to 77 Hz
Native Resolution pixels
1280 x 1024 @ 60 Hz (analog)
1280 x 1024 @ 60 Hz (digital)
Max Resolution
(Analog)
1280 x 1024 @ 75 Hz
Max Resolution
(Digital)
1280 x 1024 @ 75 Hz
Preset VESA Graphic Modes
(non-interlaced)
640 x 480 @ 60 Hz, 72 Hz, 75 Hz
720 x 400 @ 70 Hz
800 x 600 @ 60 Hz, 72 Hz, 75 Hz
1024 x 768 @ 60 Hz, 70 Hz, 75 Hz
1280 x 1024 @ 60 Hz, 75 Hz
Fail Safe Mode
Yes (limits out of range signal messages)
Maximum Pixel Clock Speed
140 MHz
User Programmable Modes
Yes, 15
Anti-Glare
Yes
Anti-Static
Yes
Default Color Temperature
6500° Kelvin
Video/Other Inputs
Plug and Play
Yes (supports VESA DDC2B and DDC/CI; PC2001 compliant)
Self Powered USB 2.0 Hub
Self-powered; two ports (cable included)
Input Impedance
75 ohms ± 2%
Sync Input
Separate sync (HSYNC/VSYNC)
Video Cable
15-pin D-sub mini connector; detached
Video Cable Lengths
70.9 in/1.8 m; detached
Mechanical
Dimensions (H x W x D)
Packaged
22.2 x 16.5 x 9.0 in (56.5 x 42.0 x 22.6 cm)
Unpacked with stand
(minimum)
14.9 x 16.30 x 11.9 in (37.8 x 41.4 x 30.1 cm)
Unpacked with stand
(maximum height)
20.0 x 16.3 x 11.9 in (50.8 x 41.4 x 30.1 cm)
Base area (footprint)
11.85 x 11.5 in (30.1 x 29.3 cm)
Panel only (without stand)
16.3 x 13.7 x 2.3 in (41.4 x 34.7 x 5.8 cm)
Packaged
20 lb (9.1 kg)
Unpacked with stand
16 lb (7.3 kg)
Panel Only (without stand)
10 lb (4.5 kg)
Service and
Three years parts, labor, and on-site service. 24-hour, 90-day, toll-free technical support. Replacement
options may include second business day on-site service, or next business day direct replacement, at HP's
sole discretion. With direct replacement, HP will ship a replacement display product directly to you. Using
the prepaid shipping labels provided, return your failed display to HP in the same packaging as the
replacement. Certain restrictions and exclusions apply. For details see your product warranty or contact HP
Customer Support.
Specification
Value
Mechanical
Packaged
Unpacked with stand
(minimum)
Unpacked with stand
(maximum height)
Packaged
20 lb (9.1 kg)
Unpacked with stand
16 lb (7.3 kg)
10 lb (4.5 kg)
Tilt Range
-5° to +35°
Swivel Range
± 45° horizontal swivel
Height Adjustable
Yes (5.1 in/13.0 cm adjustment range)
Pivot Rotation
Yes, 90° into portrait orientation
Base
Ships attached and is removable (four screws)
Power
Power Supply
Auto-ranging, 90 to 265 VAC; internal power supply
Input Power
100 ~ 240 VAC
Nominal Current
1.5 A maximum
Frequency
50 ~ 60 Hz
Maximum
44 watts
Average
32 watts
Power Cable Length
74.8 in (1.9 m); detached
Environmental
Temperature - Operating
41° to 95° F (5° to 35° C)
Temperature - Non-operating
-4° to 140° F (-20° to 60° C)
Humidity - Operating
20% to 80%, non-condensing
Humidity - Non-operating
5% to 90%
Altitude - Operating
0 to 16,404 ft (0 to 5,000 m)
Altitude - Non-operating
0 to 40,000 ft (0 to 12,192 m)
Feature
HP Display LiteSaver allows you to schedule Sleep mode at preset times to
heL protect the monitor against image retention, drastically lower power
consumption and energy costs, and extend the lifespan of the monitor.
HP Display Assistant is a software utility that enables theft deterrence and
allows monitor adjustment, color calibration, and security/asset management
using the Display Data Channel Command Interface (DDC/CI) protocol of
the connected PC.
