Replacing the Power Supply in HP Pavilion Elite Desktop PCs
This document pertains only to HP desktop computers with the following types of computer case:
Image of the computer
Before you begin
  • You need a flathead screwdriver. Note that you need a screwdriver with a long shaft to remove the inside bracket for a long graphics card.
  • Remove the Pocket Media Drive, if it is present.
  • Turn off the computer, and then disconnect all cables. Disconnect the Ethernet or modem cable before disconnecting the power cord.
  • Move the computer to a clear, flat, stable work surface over a non-carpeted floor.
  • Because you must install the replacement power supply in the same orientation as the original part, write down the orientation of the power supply onto a piece of paper; high-connector or low-connector.
    Figure : The high-connector power supply has the power connector near the top of the computer
    Image of a high-connector power supply
    Figure : The low-connector power supply has the power connector near the add-in cards
    Image of a low-connector power supply
  • During this procedure, you disconnect component cables and trace each power supply cable and disconnect it from a system component. Remember the location and type of connection. To help you remember, you may want to write a simple diagram onto a piece of paper.
    Plugs on the power supply are keyed and can be inserted only when aligned properly with the component connector. In addition, some power connectors have a latch that must be pressed or squeezed to release the cable connector from the socket.
    Figure : Tracking power supply cables as you disconnect them
    Image of tracing the power supply cable and noting the location on a piece of paper
  warning:
Use the steps in this section to replace a power supply.
  warning:
Do not attempt to disassemble or repair the power supply, or this could cause personal injury and equipment damage. Always replace the entire power supply.
Step 1
Remove the side panel.
For more information about removing the side panel, refer to the HP support document Opening the PC Case.
Image of pulling the side panel toward the back of the computer to release it
Step 2
Remove the front panel.
For more information about removing the front panel, refer to the HP support document Removing the Front Cover.
Image of lifting the tabs that secure the front panel to the computer
Step 3
Lay the computer on the side.
Image of laying the computer down
Step 4
Remove the hard disk drive cage.
For more information about removing the hard disk drive cage, refer to the HP support document Adding or Replacing a Hard Drive.
Image of the drive cage inside the computer
Step 5
Remove the inside bracket for the long graphics card:
Remove the two screws that secure the inside bracket in the computer. You may have to move cabling out of the way to reach the lower screw. Note that you need a flathead screwdriver with a long shaft to remove the lower screw.
Image of removing the two screws that secure the inside bracket for a long graphics card
Step 6
Twist the inside bracket clockwise to free the top of the bracket from the drive cage, and then...
Image of twisting the inside bracket to free the top from the drive cage
...pull the inside bracket from the computer. You may have to move cables out of the way as you withdraw the bracket.
Set the bracket aside.
Image of lifting out the inside bracket
Step 7
Disconnect the power cable from the long graphics card: Squeeze the latch on the plug, and then pull the plug from the card.
Image of removing the graphics card power plug
Step 8
Locate the power supply (1) in the computer. Trace each power supply cable to its connection to a system component, and disconnect it.
The figure shows the computer with the long graphics card removed.
Continue finding and disconnecting power cable connections until all power connections have been unplugged.
The hard disk drive cables were disconnected in step 4.
The long graphics card power cable was disconnected in step 7.
    Image of the power supply cables locations for the system components
  1. Power supply cables
  2. CD or DVD drives
  3. Motherboard main power
  4. Motherboard fan
  5. Expansion cards
Step 9
Remove the four screws that secure the power supply to the back of the computer.
Image of the screws that secure the high-connector power supply
Step 10
Locate the power supply latch at the base of the power supply inside the computer.
Image of the power supply latch at the base of the supply
Step 11
Press the power supply latch (1), and then slide the power supply (2) to the left to release it.
Image of pressing the latch and sliding the power supply into the computer
Step 12
Move the power supply to the left and then down, freeing it from the computer.
Image of moving the power supply
Step 13
Lift the power supply out of the computer.
Image of lifting a power supply out of the computer
Step 14
Lower the replacement power supply into the computer. (The illustration shows a low-connector power supply installation.)
You must install the replacement power supply in the same orientation as the original unit; make sure the orientation of your power supply before inserting it into the computer. Refer to the orientation that was written down earlier if necessary; either high-connector or low-connector type.
Image of inserting a power supply into the computer
Step 15
Align the power supply in the opening in the back of the computer.
Image of the power supply aligned in the opening in the back of the computer
Step 16
Slide the power supply to the right (toward the back of the computer) until the latch locks it into place.
Image of sliding the power supply into the opening in the back of the computer
Step 17
Insert and tighten the four screws that secure the power supply to the back of the computer.
Image of the screws on a low-connector power supply
Step 18
Route the power supply cables (1) to each of the system components, and then connect each component.
  • The figure shows the computer with the long graphics card removed.
  • The long graphics card power cable and the hard disk drive cables are connected in the later steps.
  • Your computer may not use all the connectors on the power supply. Be sure to check your record and connect a power supply plug to each system component.
  2. CD or DVD drives
  4. Motherboard fan
  5. Expansion cards
Step 19
Connect the power cable to the long graphics card.
Image of connecting the power cable to the long graphics card
Step 20
Grasp the inside bracket, and...
Image of the inside bracket for the long graphics card
...insert the inside bracket over the long graphics card, placing the foot of the bracket over the lower screw hole in the computer. You may have to move cables out of the way as you insert the bracket.
Image of inserting the inside bracket over the long graphics card
Step 21
Twist the top of the inside bracket counter-clockwise into place over the graphics card power connector and into the drive cage. You may have to press the inside bracket down onto the graphics card and power connector as you twist it to insert the tip of the bracket into the drive cage. Ensure there is nothing between the bracket and the card.
Image of twisting the top of the inside bracket counter-clockwise
Step 22
Insert and tighten the two screws that secure the inside bracket in the computer. Note that you need a flathead screwdriver with a long shaft to insert the lower screw.
Image of inserting the two screws that secure the inside bracket for the long graphics card
Step 23
Connect the cables and replace the hard disk drive cage.
For more information about replacing the hard disk drive cage, refer to the HP support documentAdding or Replacing a Hard Drive.
Image of connecting the power and SATA data cables to the hard disk drives in the cage
Step 24
Set the computer upright.
Image of setting the computer upright
Step 25
Replace the front panel.
For more information about replacing the front panel, refer to the HP support document Removing the Front Cover.
Image of pressing the right side of the front panel into the computer
Step 26
Replace the side panel.
For more information, refer to the HP support document Opening the PC Case.
Image of the side panel positioned over the side of the computer
