HP 17bII+ Financial Calculator - Currency Conversions
Currency conversions
The HP 17bII+ the ability to convert between currencies. Select two currencies from the built-in list, enter an exchange rate, and convert back and forth between the currencies. The menu label is accessed from the main menu screen as shown in Figure 1 below.
Figure : Displaying the main menu options
When selected, the HP 17bII+ displays the menu shown in Figure 2.
Figure : Displaying the next menu options
The default currencies displayed are US dollars and Euros. These can be changed using the menu label to choose from more than 20 built-in currency symbols (as well as two generic currencies to represent any other currencies desired). The menu label is used to store the exchange rate between the currencies. Once stored, enter the units of the currency you wish to convert and press the appropriate currency menu label to store them, then press the other currency menu label and the conversion is made and displayed.
The and menu labels allow you to store sets of frequent currency conversions and recall them without having to rebuild the currencies again. These functions are covered in the HP 17bII+ user’s guide.
Practice converting currencies
Example 1
If the exchange rate is such that one dollar is worth 0.6757 Euros, how many Euros would you have if you converted $212?
Solution
Keystroke
Figure : Displaying the result
Answer
The result is 143.25 Euros.
Example 2
If an item costs 175 Euros, how much would it be in dollars at the same exchange rate?
Solution
Keystroke
Answer
The result is $258.99.
Example 3
If the exchange rate changes such that one dollar is now worth 0.65 Euros, convert 104 Euros to dollars and then 500 dollars to Euros.
Solution
Keystroke
Answer
104 Euros would equal 160 dollars and 500 dollars would equal 325 Euros.
Example 4
Change currency one to be British Pounds. Then convert 40 British Pounds to Euros, if the exchange rate is such that one British Pound is equal to 1.32625 Euros. Make British Pounds “currency 1” and Euros “currency 2.”
Solution
Keystroke
Figure : Selecting CURRENCY 1
Figure : Selecting CURRENCY 2
Figure : Entering the rate
Answer
40 British Pounds would be equal to 53.05 Euros, at the stated exchange rate.
Country: Flag Thailand
