HP Indigo WS6000 Digital Press - Maintaining the web handling system
At least once a week, do the following:
  • Inspect all nips and rollers for scratches.
  • Clean all nips and rollers.
  • Inspect the impression roller.
  • Clean the impression roller with IPA.
  • Inspect the internal buffer system rails. Grease if you see dry rails or serious ink leaks
At least once a month, do the following:
  • Inspect all belts for cracks.
  • Check the tension of each belt.
  • Verify that the bristles of both electrostatic brushes are straight and point towards the substrate.
  • At the unwinder, grease the expanding shaft gear and rollers.
  • Inspect the unwinder active dancer grease nipples. Lubricate if needed.
  • Inspect the rewinder moving shelf grease nipples. Lubricate if needed.
  • Inspect and grease the drive unit gears.
