HP Indigo WS6000 Digital Press - Touchscreen panels
This section describes how to use the touchscreen panels on the unwinder and the rewinder.
Touch the required button or icon on the screen to select an option. Some components are read-only and are not sensitive to touch.
If you touch a field that requires input, a virtual keyboard appears.
If the content of one screen continues onto another screen, touch to open the next screen.
The unwinder and rewinder touchscreens include the following components, which are always visible.
  • Main toolbar
  • Print controls
Main toolbar
The main toolbar is used to access frequently used screens.
The main toolbar includes the following icons:
  • — Opens the Main screen
  • — Opens the Function screens
  • — Opens the Tension screen
  • — Opens the Diagnostic screens
  • — Opens the Packer arm screen. This icon appears only on the rewinder touchscreen.
Print controls
The print controls show the press state and operates the press.
The print controls include the following icons:
  • Stop — Stops the movement of the substrate thought the press.
  • Pause — Pauses the movement of the substrate thought the press for one minute.
  • Inspect — Slows the movement of the substrate thought the press. This icon appears only on the rewinder touchscreen.
Unwinder main screen
Use the Unwinder main screen to view basic information about the unwinder.
    Figure : Unwinder main screen
  1. Current job name
  2. Rotational direction of the substrate roll that remains on the substrate roll
  3. Substrate tension the unwinder
  4. Diameter of the substrate roll
  5. Estimated length of substrate
Unwinder function screens
The Unwinder function screens enable you to use the basic unwinder functions.
    Figure : Unwinder function 1 screen
  1. Determines the substrate speed during web feed
  2. Changes the rotational direction of the substrate roll
  3. Jogs the substrate forward or backward
  4. Engages or disengages the right clamp
  5. Engages or disengages both clamps
  6. Engages or disengages the left clamp
  7. Lowers clamps and releases tension / Raises clamps and increases tension
    Figure : Unwinder function 2 screen
  1. Lowers clamps and releases tension / Raises clamps and increases tension
  2. Calibrates the unwinder for a substrate roll core with a diameter of 6 inches
  3. Calibrates the unwinder for a substrate roll core with a diameter of 3 inches
Unwinder tension screen
Use the Unwinder tension screen to change substrate tension in the unwinder.
    Figure : Unwinder tension screen
  1. Changes the substrate tension in the unwinder
Unwinder diagnostic screens
Use the Unwinder diagnostic screens to diagnose issues with the unwinder.
    Figure : Unwinder diagnostic 1 screen
  1. Sends the impression roller to its home position
  2. Pneumatically engages or disengages the impression roller
  3. Electronically engages or disengages the impression roller
    Figure : Unwinder diagnostic 2 screen
  1. Engages or disengages the feed input nip roller
  2. Rotates the feed input nip roller
    Figure : Unwinder diagnostic 3 screen
  1. Displays the status of the dancer sensors
  2. Displays the status of the dancer web brake sensor
  3. Displays the status of the dancer empty sensor
  4. Displays the status of the roll position sensor
    Figure : Unwinder diagnostic 4 screen
  1. Displays technician information
  2. Accesses the operating system
  3. Brightens or dims the touchscreen
  4. Disables the touchscreen for one minute so that you can clean it
Rewinder main screen
Use the Rewinder main screen to view basic information about the rewinder.
    Figure : Rewinder main screen
  1. Current job name
  3. Substrate tension in the rewinder
  5. Estimated length of substrate that has been rolled onto the substrate roll
Rewinder function screens
The Rewinder function screens enable you to use the basic rewinder functions.
    Figure : Rewinder function 1 screen
    Figure : Rewinder function 2 screen
  1. Enables or disables the web guide sensor
  2. Enables replacement of substrate roll
  3. Inflates or deflates the shaft
Rewinder tension screen
Use the Rewinder tension screen to change substrate tension in the rewinder.
    Figure : Rewinder tension screen
  1. Changes the substrate tension in the rewinder
  2. Changes the taper tension percentage
Rewinder diagnostic screens
Use the Rewinder diagnostic screens to diagnose issues with the rewinder.
    Figure : Rewinder diagnostic 1 screen
  1. Displays the position of the dancer
    Figure : Rewinder diagnostic 2 screen
    Figure : Rewinder diagnostic 3 screen
  1. Sets the small diameter for potentiometer calibration
  2. Sets the big diameter for potentiometer calibration
  3. Displays the diameter of the substrate roll
    Figure : Rewinder diagnostic 4 screen
  1. Sets -40° for dancer calibration
  2. Sets +40° for dancer calibration
  3. Displays the position of the dancer
Rewinder packer arm screen
Use the Rewinder packer arm screen to change the packer arm settings.
    Figure : Rewinder packer arm screen
  1. Changes the packer arm pressure
  2. Engages or disengages the packer arm
  3. Activates or deactivates the packer arm clamp
