HP ProBook 4710s Notebook PC - Removing and Replacing the Optical Drive
This document is provided to assist in removing and replacing the Optical Drive for the HP ProBook 4710s Notebook PC.
Minimum skill level
Tools required
  • Torx 8 (T8) screwdriver
  • Small, flat-bladed screwdriver or a flat-bladed alignment tool
Parts required
The replacement part number will vary depending on the Optical Drive that is being replaced. If a part is listed as 'Yes' under 'Requires Return' then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Blu-ray Disc (BD) SuperMulti optical drive with DVD R/RW Double-Layer - SATA interface
535759-001
Yes
DVD-ROM drive - 12.7mm form factor
535760-001
Yes
DVD+/-RW and CD-RW Super Multi Double-Layer combo drive with LightScribe - 12.7mm form factor
535761-001
Yes
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labeled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the Optical Drive, click on the link below. Or use the product video listing on the HP Services Media Library, then select Optical Drive from the menu on the upper left hand side of the screen.
Click here to view the Optical Drive removal video (right-click on the link to open in a new window/tab).
  2. Remove the battery, switch cover and keyboard.
    Click Here for instructions to remove the Battery, Switch Cover and Keyboard.
  3. Remove the bronze 6mm T8 Torx-head locking screw that secures the optical drive to the base enclosure.
  4. Using a flat bladed tool, push the tab on the rear of the optical drive to partially remove it.
  5. Remove the optical drive from the base enclosure.
Optical Drive replacement
  1. Insert the optical drive into the optical drive bay until the tray door bezel is flush with the side of the base enclosure.
  2. Replace the bronze 6mm T8 Torx-head screw that secures the optical drive to the base enclosure.
Parts return
