    Looking for Site Help?
HP 12c Calculator - Analyzing Financial Problems
The HP 12c Financial calculator provides functions for the two most commonly used methods of discounted cash flow analysis: (net present value) and (internal rate of return). These functions enable analyzing financial problems involving cash flows, that is, money paid out or received, occurring at regular intervals.
NPV is calculated by adding the initial investment, represented as a negative cash flow, to the present value of the anticipated future cash flows. The interest rate, i, will be referred to NPV and IRR as the rate of return. The value of NPV indicates the result of the investment:
  • If NPV is positive, the financial value of the investor’s assets would be increased ― the investment is financially attractive.
  • If NPV is zero, the financial value of the investor’s assets would not change ― the investor is indifferent to the investment.
  • If NPV is negative, the financial value of the investor’s assets would be decreased ― the investment is not financially attractive.
The greater the NPV, the more the financial value of the investor’s assets increases.
IRR is the rate of return at which the discounted future cash flows equal the initial cash outlay ― IRR is the discount rate at which NPV is zero. The value of IRR relative to the present value discount rate also indicates the result of the investment:
  • If IRR is greater than the desired rate of return, the investment is financially attractive.
  • If IRR is equal to the desired rate of return, the investor is indifferent to the investment.
  • If IRR is less than the desired rate of return, the investment is not financially attractive.
Calculating the net present value (NPV) for ungrouped cash flows
The amount of the initial investment (CF0) is entered into the calculator using the keys. Pressing stores CF0 in storage register R0 and also stores the number 0 in the n register.
The amounts of the subsequent cash flows are stored in the order they occur in the remaining storage registers: CF1 through CF9 in R1 through R9, and CF10 through CF19 in R.0 through R.9, respectively. If there is a CF20, that amount is stored in the FV register.
Each cash flow (CF1, CF2, etc.) is designated CFj, where j takes on values from 1 up to the number of the final cash flow. The amount of a cash flow is entered using the keys. Each time is pressed, the amount in the display is stored in the next available storage register, and the number in the n register is increased by 1. This register therefore counts how many cash flow amounts, in addition to the initial investment, CF0, have been entered.
When entering cash flow amounts, including the initial investment CF0, enter a negative cash flow by pressing after keying in the number.
To enter the cash flow amounts:
  1. Press to clear the financial and storage registers.
  2. Key in the amount of the initial investment, press if that cash flow is negative, then press .
  3. Key in the amount of the next cash flow, press if the cash flow is negative, then press . If a cash flow amount is zero, press .
  4. Repeat step 3 for each cash flow until all have been entered.
With the amounts of the cash flows stored in the calculator’s registers, calculate NPV as follows:
  1. Enter the interest rate, using or .
  2. Press .
The calculated value of NPV appears in the display and is automatically stored in the PV register.
Example for calculating the net present value (NPV) for ungrouped cash flows
An investor has an opportunity to buy a duplex for $80,000 and would like a return of at least 13%. The investor expects to keep the duplex five years and then sell it for $130,000 and anticipates the cash flows shown in the diagram below. Calculate NPV to determine whether the investment would result in a return or a loss.
Figure : Cash Flow
The cash flow amount of $4,500 occurs twice; these cash flows are not consecutive.
Keystroke
0.00
Clears financial and storage registers.
–80,000.00
Stores CF0 (with minus sign for a negative cash flow).
–500.00
Stores CF1 (with minus sign for a negative cash flow).
4,500.00
Stores CF2.
5,500.00
Stores CF3.
4,500.00
Stores CF4.
130,000.00
Stores CF5.
5.00
Checks number of cash flow amounts entered (in addition to CF0).
13.00
Stores i.
212.18
NPV.
Since NPV is positive, the investment would increase the financial value of the investor’s assets.
Calculating the net present value (NPV) for grouped cash flows
The HP 12c Financial calculator stores a maximum of 20 cash flow amounts (in addition to the initial investment CF0). However, the calculator can handle problems involving more than 20 cash flows if there are equal, consecutive cash flows occurring among the other cash flows. For such problems, enter the amount(s) of the cash flows, and the number of times up to 99 each amount occurs consecutively. The number of times a cash flow occurs is designated by Nj, , and it corresponds to the cash flow amount, CFj. Each value for Nj is stored in a special register inside the calculator.
The grouping of equal, consecutive cash flows is provided to minimize the number of storage registers required.
Follow these steps to enter the amounts of the cash flows and the number of times they occur consecutively:
  3. If the initial investment consists of more than one cash flow of the amount entered in step 2, key in the number of times those cash flows occur, and then press . If is not pressed, the calculator assumes that N0 is 1.
  4. Key in the amount of the next cash flow. Press if that cash flow is negative, and then press . If the cash flow amount is zero in the next period, press .
  5. If the amount entered in step 4 occurs more than once consecutively, key in the number of times that cash flow amount occurs, then press . If is not pressed, the calculator assumes that Nj is 1 for the CFj just entered.
  6. Repeat steps 4 and 5 for each CFj and Nj until all cash flows have been entered.
With the amounts of the cash flows and the number of times they occur consecutively stored in the calculator, NPV can be calculated by entering the interest rate and pressing .
Example for calculating the net present value (NPV) for grouped cash flows
An investor has an opportunity to purchase a piece of property for $79,000, and he would like a 131/2% return. He expects to be able to sell it after 10 years for $100,000 and anticipates the yearly cash flows shown in the table below:
Year
Cash Flow
Year
Cash Flow
1
$14,000
6
$9,100
2
$11,000
7
$9,000
3
$10,000
8
$9,000
4
$10,000
9
$4,500
5
$10,000
10
$100,000
Since two cash flow amounts ($10,000 and $9,000) are repeated consecutively, the number of storage registers required can be minimized by using this method:
Keystroke
0.00
–79,000.00
Initial investment (with minus sign for a negative cash flow).
14,000.00
First cash flow amount.
11,000.00
Next cash flow amount.
10,000.00
3.00
Number of times this cash flow amount occurs consecutively.
9,100.00
9,000.00
2.00
4,500.00
100,000.00
Final cash flow amount.
7.00
Seven different cash flow amounts have been entered.
13.50
Stores i.
907.77
Calculates NPV.
Since NPV is positive, the investment would increase the financial value of the investor’s assets by $907.77.
Calculating internal rate of return (IRR)
To calculate the internal rate of return:
  1. Enter the cash flows using either of the methods described above under calculating net present value.
  2. Press .
The calculated value of IRR appears in the display and also is automatically stored in the i register.
Remember that the function may take a significant amount of time to produce an answer, during which the calculator displays, 'running.'
Example for calculating internal rate of return (IRR)
The NPV calculated in the preceding example was positive, indicating that the actual rate of return, that is, the IRR, was greater than the 131/2 used in the calculation. Find the IRR. Assuming the cash flows are still stored in the calculator, press :
Keystroke
13.72
IRR is 13.72%.
The value calculated by is the periodic rate of return. If the cash flow periods are other than years (for example, months or quarters), calculate the nominal annual rate of return by multiplying the periodic IRR by the number of periods per year.
Reviewing cash flow entries
To review the cash flow entries:
  • To display a single cash flow amount, press , then key in the number of the register containing the cash flow amount to be displayed. Alternatively, store the number of that cash flow amount, that is, the value of j for the CFj desired, in the n register, then press .
  • To review all the cash flow amounts, press repeatedly. This displays the cash flow amounts in the reverse order — that is, beginning with the final cash flow and proceeding to CF0.
  • To display the number of times a cash flow amount occurs consecutively — that is, to display the Nj for a CFj — store the number of that cash flow amount, that is, the value of j, in the n register, then press .
  • To review all the cash flow amounts together with the number of times each cash flow amount occurs consecutively, that is, to review each CFj and Nj pair, press repeatedly. This displays Nj followed by CFj beginning with the final cash flow amount and proceeding to N0 and CF0.
Neither nor changes the number in the n register. However, each time is pressed, the number in the n register is decreased by 1.
Example for reviewing cash flow entries
To display the fifth cash flow amount and the number of times that amount occurs consecutively from the previous example:
Keystroke
9,000.00
CF5.
5.00
Stores the value of j in the n register.
2.00
N5.
7.00
Resets the number in the n register to its original value.
Changing cash flow entries
To change a cash flow amount:
  1. Key the amount into the display.
  2. Press .
  3. Key in the number of the register containing the cash flow amount to be changed.
To change the number of times a cash flow amount occurs consecutively — that is, to change the Nj for a CFj:
  1. Store the number of that cash flow amount, that is, j, in the n register.
  2. Key the number of times the cash flow amount occurs consecutively into the display.
  3. Press .
When changes are made to the number in the n register in order to change a value for Nj, be sure to reset the number in the n register to the total number of cash flow amounts originally entered (not including the amount of the initial investment CF0). If this is not done, NPV and IRR calculations will yield incorrect results.
Example for changing cash flow entries
With the cash flows now stored in the calculator from the previous example, change CF2 from $11,000 to $9,000, and then calculate the new NPV for a 131/2% return.
Keystroke
9,000.00
Stores the new CF2 in R2.
13.50
Stores i.
–644.75
The new NPV.
Since this NPV is negative, the investment with this change would decrease the financial value of the investor’s assets.
Country: Flag Thailand
