To use the Processing and Adjusting pages option, perform the following steps:
Launch HP Smart Document Scan Software and select the desired profile.
In the Profile Settings dialog box, click the Process tab to specify the image and document processing settings of a profile.
You will see the Process tab as shown in the following screen:
The following operations can be carried out automatically:
- Straightening skewed pages
- Orienting pages right side up
- Cropping pages
- Resizing pages
- Detecting blank pages
- Detecting bar codes
Beyond these automatic processing options, further individual post-processing is possible for each page in the Preview Pages window as well.
You can also specify a document separator to be used to automatically separate a stack of pages into separate documents. The document separator can be one of the following:
- A fixed number of pages for each document
- A barcode found on the page
- A blank page
Adjusting Pages before scanning:
You can specify the following settings on the Process tab, under the Adjust Page area.
The thumbnails of blank pages continue to appear in the thumbnail view even if this option is selected but none of them are going to be saved.
