    Microsoft Support for Windows 7 ended on Jan 14, 2020
    - HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
    - If your computer is not compatible for upgrade to Windows 10, we can help to find the perfect computer for you. Check our Weekly deals!
HP Printers - Installing and Using the Windows Built-in Print Driver
This document is for HP printers and Windows computers.
Windows contains built-in print drivers for many types of printers. These drivers support basic printer functionality for most print jobs.
A full feature driver from HP might be available to make use of all your printer features. To see if a driver is available, go to 123.hp.com.
Step 1: Set Windows Update to automatically download driver software
Confirm that your computer is set to automatically download driver software.
  1. In Windows, search for and open Change device installation settings.
  2. In the Device Installation Settings window, select the Yes option, and then click Save Changes.
    Example of selecting the Yes option
Step 2: Connect your printer to the computer
Connect your printer to the computer before starting the driver installation.
Step 3: Install the print driver with the Add a Printer wizard
Use the Windows Add a Printer wizard to install the built-in print driver.
Step 5: Scan a document (if supported)
Scan a document to make sure the scanner is working.
  • If you can scan, the built-in driver installed and is working.
  • If you cannot scan, continue to the frequently asked questions for help.
Frequently asked questions
Consult these commonly asked questions to troubleshoot issues and to learn how to use your printer with the built-in driver.
