HP ProBook 4410s Notebook PC - Removing and Replacing the Memory modules
This document is provided to assist in removing and replacing the Memory modules for the HP ProBook 4410s Notebook PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the Memory modules that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
1.0 GB, 800 MHz, CL=6 PC2-6400, DDR2 SDRAM Small Outline Dual In-Line Memory Module (SODIMM)
536427-001 (Modified)
Yes
2.0 GB, 800 MHz, CL=6 PC2-6400, DDR2 SDRAM Small Outline Dual In-Line Memory Module (SODIMM)
536428-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the Memory modules, click on the link below. Or use the product video listing on the HP Services Media Library then select Memory modules from the menu on the upper left hand side of the screen.
Click here to view the Memory modules removal video (right-click on the link to open in a new window/tab).
  2. Push both arms outward simultaneously to release the memory board to the spring tension position.
    The primary and expansion memory slots are both located under the keyboard. The primary memory slot is located on the bottom and the expansion memory slot is located on top. If an expansion memory board is installed, it must be removed before the primary memory board can be removed.
  3. Grasp the memory board by the edges and pull gently to remove it.
    When handling a memory board, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
  4. Place the memory module in an electrostatic dissipating bag.
Memory modules replacement
  1. Remove the memory module from the electrostatic dissipating bag.
  2. Grasp the memory module by its corners.
  3. Locate the alignment notch on the memory module and align it with the memory module connector on the system board.
  4. Gently push the memory module into the memory module connector until it is secure.
  5. Push the exposed edge of the memory module down until you hear the click of the two retention arms.
Parts return
