This document is provided to assist in removing and replacing the Keyboard for the HP ProBook 4410s Notebook PC.
- ${title}
- ${title}
- ${title}
- ${title}
HP ProBook 4410s Notebook PC - Removing and Replacing the Keyboard
Minimum skill level
Tools required
Small, Phillips-head P00 screwdriver.
Parts required
note:Part numbers are subject to change.
The replacement part number will vary depending on the Keyboard that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Keyboard
536537-xx1 (Modified)
No
Keyboard
536410-xx1 (Modified)
No
The part number will vary based on the country. Click here
for a list of country specific spare part numbers.
note:For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labelled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labelled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the Keyboard, click on the link below. Or use the product video listing on the HP Services Media Library then select Keyboard from the menu on the upper left hand side of the screen.
Click here to view the Keyboard removal video (right-click on the link to open in a new window/tab).
Keyboard removal
Review the safety considerations before performing the steps listed below by clicking on the following link:
Failure to comply with the precautions could result in damage to your product or loss of data. -
Remove the battery. Click here for instructions on how to remove the battery.
Remove the switch cover. Click here for instructions on how to remove the switch cover.
Remove the three 3mm P00 Phillips-head screws that secure the keyboard to the top cover.
Slide the keyboard toward the rear of the notebook to release the retaining tabs.
Flip the keyboard toward the right side of the notebook and rest it face down.
Gently lift the locking bar on the keyboard ZIF connector and remove the ribbon cable.
Use care to prevent damaging the ZIF connector and ribbon cable. -
Remove the keyboard from the base enclosure.
Keyboard replacement
Place the keyboard face down on the palm rest.
Insert the keyboard ribbon cable into the ZIF connector on the system board.
Push the locking bar down to secure the keyboard cable in the ZIF connector.
Flip the keyboard toward the center of the notebook and align the retaining tabs on the front of the keyboard with the slots on the base enclosure.
Press down on the outside edges of the keyboard to insert the remaining tabs into their respective slots.
While pressing down on the front and rear edges, slide the keyboard forward until it is securely seated under the lip of the palm rest.
Replace the three 3mm P00 Phillips-head screws that secure the keyboard to the top cover.
Replace the switch cover. Click here for instructions on how to replace the switch cover.
Replace the battery. Click here for instructions on how to replace the battery.
Parts return
If your part requires return then click on the appropriate link below:
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
