    We are upgrading our website
HP Indigo 7000 Digital Press - Replacing the PIP Foil
Replace the PIP foil when it is damaged or aged.
Wear safety glasses and gloves for this procedure.
  1. On the touch screen, click the Main Menu, Blanket and PIP, and Replace PIP. The Replace PIP wizard opens.
  2. Use the barcode reader to read the label on the new PIP foil wrapper. Enter the reason for PIP replacement and click Next.
  3. In the touch screen, click the Prepare button, and wait until the temperature is 60 °C (140 °F) or less before proceeding.
  4. Remove the cleaning station, cleaning station blade, and charge roller, and open the PIP latch.
  5. Access the PIP area, open the upper feed door and lift the feeder bridge.
  6. Press the Inching button to advance the press until the PIP trailing edge is in view.
  7. Unlock the PIP latch and remove the PIP leading edge from the slot. Hold it away from the PIP drum. Using the inching button, turn the drum and lift off the PIP as the drum rotates.
    Figure : PIP latch location
  8. Make sure that the PIP underlayer surface is clean and intact. If necessary, wipe it with a lint-free wipe moistened with imaging oil.
Installing a new PIP foil
Install a new PIP after you have removed the old one, and have ensured that the PIP underlayer is in good condition. This procedure assumes that you have opened the press doors, removed the cleaning station and have free access to the PIP area.
Perform this procedure under dim lighting conditions to protect the PIP. Wear safety glasses and gloves for this procedure.
Always protect the exposed PIP from direct light.
To install the new PIP:
  1. Remove the PIP from its wrapping. Wipe the cartridge clean with a lint-free wipe. Pull out the leading edge about 2.5 cm (1 inch), and remove the self-adhesive tab.
  2. Using the squeezer bottle, apply imaging oil to all visible parts of the PIP underlayer.
  3. Fix the PIP leading edge onto the drum as follows:
    1. Insert the leading edge of the PIP completely into the slot.
    2. Adjust the PIP inside the holder so that the two black mark-lines on the PIP are parallel with the holder lip.
    3. Insert the PIP holder in its position between the press walls.
    4. Make sure the lines are parallel and centered so that the trailing edge is also parallel and centered on the drum.
    5. Lock the PIP latch while holding the PIP against the drum.
  4. Press the Inching button to rotate the PIP drum, and apply the PIP to the drum. Remove the white PIP protective paper by gently pulling its tab, as you inch the PIP drum.
  5. Continue applying imaging oil to dry sections of the drum, especially underneath the PIP trailing edge.
  6. Place the PIP trailing edge over the leading edge. Verify contact by touching it with your hand.
  7. Reinstall the cleaning station, and close the front printing engine door.
  8. Lower the bridge and close the upper feed door.
  9. In the PIP replacement wizard, enter the new PIP information.
Country: Flag Thailand
