HP Indigo 7000 Digital Press - First transfer calibration
Adjust the pressure between the PIP and ITM drums on the front and rear controls using the First Transfer calibration.
Use the First Transfer calibration:
  • After you change the blanket.
  • When the ink coverage is partial and blank patches in the shape of white clouds appear on either side of the printed image.
  • When the highlight dots (small dots) do not transfer to the substrate.
    Before performing the calibration, the press must be configured for either the manual or automatic mode.
    Use a wizard to calibrate first transfer pressure:
Calibrating the pressure
  • The First Transfer wizard uses a job which consists of nine sheets with two separations each. The PIP to ITM pressure increases from one sheet to the next.
  • The job image consists of two columns with six triangles each. Each column is equivalent to a different side of the drum.
    During the calibration procedure:
  • Identify the sheet number with at least three triangles in a column.
  • Triangle fragments count as a triangle.
  • Spread 5 is the first one to print 3 triangles in the left column.
  • Spread 6 is the first to print in the right column.
  1. On the touch screen, click the Main Menu, Blanket and PIP, and First Transfer. The First Transfer wizard opens.
  2. Follow the instructions in the wizard:
    • Enter the sheet number (printed on the triangles) in the correct column.
    • In the First Transfer Calibration, enter the print number in the correct column. The print number appears in each triangle.
    • If you cannot identify three triangles in a column in any of the nine prints, click 9, and then Next and Finish.
    • Restart this procedure at step 1.
    • If three triangles appear in all nine prints, click 1, and then Next and Finish. Restart this procedure at step 1.
Figure : Spread 4 (incorrect front pressure)
Figure : Spread 5 (correct front pressure)
Figure : Spread 6 (correct rear pressure)
Figure : Spread 7 (too much pressure)
Country: Flag Thailand
